Blower Switch on my 2003 Excursion
Old May 16, 2016 | 03:42 PM
mribbich's Avatar
mribbich
Blower only works on high could it be the switch or the motor. My guess it is the switch. Thanks for any help!!!
Marv.
Old May 16, 2016 | 08:15 PM
projectSHO89's Avatar
projectSHO89
Neither.
Resistor pack, assuming a manual climate control.
Old May 17, 2016 | 05:29 AM
mribbich's Avatar
mribbich
Where do I find the Resistor Pack on the Excursion? Thanks!!!
Marv.
Old May 17, 2016 | 06:08 AM
projectSHO89
google search
Old May 17, 2016 | 06:15 AM
mribbich's Avatar
mribbich
Thanks Again!!!! will give it a try.
Old May 17, 2016 | 05:30 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by projectSHO89
google search
Made me look.
Sho, if you don't mind, your opinion on this vid I found that piqued my curiosity for the tech folder:
Stewart
Old May 17, 2016 | 07:18 PM
mribbich's Avatar
mribbich
Removed Resistor Pack and found the plug end melted and rusted the resistor rusted also. Will replace both and hope for the best. Thanks!!! to all for your help.
Marv.
Old May 18, 2016 | 07:09 AM
muj0's Avatar
muj0
Yup. Just did this a month ago on mine. Now I get all levels of fan speed . My resistor was so corroded, I had to snip the wires and pigtail the new one on. Works great though! If you buy the resistor, spend the extra $3 for one that comes with the wiring harness just in case you have the same issue I did.
Here's the link to the one I got:
Amazon.com: Dorman 973-404 Ford Truck Blower Motor Resistor and Harness Kit: Automotive Amazon.com: Dorman 973-404 Ford Truck Blower Motor Resistor and Harness Kit: Automotive
Old May 18, 2016 | 07:29 AM
mribbich's Avatar
mribbich
Thanks for the heads up ordered one today.
Marv.
Old May 19, 2016 | 08:08 AM
wpsharpshooter's Avatar
wpsharpshooter
Im having a similar issue. I have nothing blowing out. On any speed. Sometimes it will kick on going down the road at times but its a crap shoot. Rode the whole way to work this morning and it never came on. Think this is the culprit?
Old May 19, 2016 | 08:20 AM
projectSHO89
Probably not, but do a visual exam of the connectors and look for evidence of corrosion or overheating that might have caused a very intermittent connection.
Most likely, you have a blower motor with worn out brushes.
Old May 19, 2016 | 08:23 AM
wpsharpshooter
Well thats outstanding... Was hoping it was an easy fix like switching out this resistor..
ETA, I will note that there isnt any noise from the blower motor. No squeaking or groaning noise.. I can hear the selector switch move and hear the defrost door open up when switched (hope that makes sense)
Old May 19, 2016 | 01:15 PM
projectSHO89
Those things are normal but unrelated to the operation of the blower motor itself.
The resistor cannot cause a complete loss of blower function as the HIGH speed setting completely bypasses the resistor. There are other things that can cause the blower motor to not operate, but, when it's intermittent, it's almost always the motor itself at fault.
There is troubleshooting that can be done to pinpoint the fault.
Old May 19, 2016 | 01:22 PM
wpsharpshooter
So your thinking I need this then correct?
Murray Climate Control 76900 - Blower Motor | O'Reilly Auto Parts
ScottyC50
Jun 28, 2021 07:12 AM
CNC
Dec 28, 2016 06:08 PM
DaveBB
Nov 30, 2013 06:15 PM
blloyd
Nov 1, 2009 07:32 PM
frontco
Electrical Systems/Wiring
Nov 8, 2004 07:51 PM
