Lift Kit
Old Dec 23, 2008 | 02:39 PM
Wopstar's Avatar
Wopstar
Lift Kit
I have a 2003 2wd Excursion (V10). I want to put a Fabtech 6" lift eventually but right now I am looking for a smaller lift to hold me over for a while. Looking for about 2-3 inches but I can't seem to find anything. Can you guys help me out here?
Old Dec 23, 2008 | 06:25 PM
FordTruckGirl77's Avatar
FordTruckGirl77
This has been asked many times (myself included) You can get a small lift by either add-a-leafs or get the F350 springs. I believe the F350 springs will give you 2 inches or so and you could add-a-leaf to those if you wanted.
Old Dec 23, 2008 | 06:57 PM
BAJI26's Avatar
BAJI26
Will it still work on his 2wd?
We, 2wd have coil spring in front.
I'm interested in this also!
Old Dec 23, 2008 | 07:10 PM
FordTruckGirl77
Hmmmmm I didnt even pay attention to the 2wd!!!
On a 2wd I am not 100% sure but you would probably have to do a block lift on the front. I lifted my old X (2wd) with frame blocks. Would never do it again, it was done for free when I had to have frame work done and I dont think it was very safe.
I'm sure one of the guys on here will chime in and let you know how to get a small lift on the 2wds.
Old Dec 23, 2008 | 07:42 PM
GR$$N$'s Avatar
GR$$N$
o damn.its 2wd.if it was 4 im getting rid of my 8" ranch pretty soon. but anyways,i THINK you can get a spacer kit for the springs.lifts it 2" or so,possibly even a cheap spindle lift which you can go 4" maximum without having different control arms/etc.someone correct me if im wrong but this is how my old truck used to be lifted,ive never lifted a 2wd X.
Old Dec 23, 2008 | 08:10 PM
FordTruckGirl77
Originally Posted by GR$$N$
o damn.its 2wd.if it was 4 im getting rid of my 8" ranch pretty soon..
For Free?!? Or how much? I live very close to you so that wouldnt be a problem...
Old Dec 23, 2008 | 08:18 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I most definately can.... check out my sig
The "lift bug" has bitten you, I went through this are there is MUCH you need to know.
Myself, igotoneforya, and ieathybrids are the only 3 on here with lifted 2wd trucks. I always told them we'd start an empidemic.
Check out this thread here: https://www.ford-trucks.com/forums/6...lly-caved.html
Read the thread, read it twice, or you'll soon find out, lifting and lifts aren't so nice.....
Old Dec 23, 2008 | 09:05 PM
TYZ78F150's Avatar
TYZ78F150
Will the 8" rancho fit an 04' with a 5.4? I might be interested, if you'll ship?
Old Dec 23, 2008 | 11:26 PM
GR$$N$'s Avatar
GR$$N$
fordtruckgirl77 and tyz78f150. i dont wana thread jack so if you have further questions then pm me.not for free but for a price.i have to wait to get my 14" deavers first. and i have no idea if it will fit an 04. i dont see y not.shipping can be worked out
Old Dec 24, 2008 | 01:04 AM
Monsta's Avatar
Monsta
Sit. Stay.
To the OP; there is a spring spacer for the fronts on eBay for about $70. Get some add-a-leafs for the rear and that should give you the 2-3" you're looking for. Make sure you budget for an alignment w/new alignment cams. You'll need it afterward.
Old Dec 24, 2008 | 07:14 AM
TYZ78F150's Avatar
TYZ78F150
Do you send a pm by clicking on your name? If so, it's not giving me that option for some reason.
Old Dec 24, 2008 | 07:25 AM
SGnAZ's Avatar
SGnAZ
I think you have to get up to 25 posts.
Better yet-Become a Supporter
Old Dec 24, 2008 | 08:17 AM
fordquist's Avatar
fordquist
I am no expert, just wanted to give a suggestion. If this is temporary, and you dont want to waste money you may think about doing this. Put air bags on the rear, and coil spacers on front. My firestone bags give me an easy two inches at less than 60psi. When you do go to a larger lift in the future, you would still be able to keep your bags with some sort of blocks on your bag mounts( have seen other threads for using bags on a lift on this forum). With bags in the rear, you should have no problem matching the rear heigth to the front coil spacer heigth. Bags with on-board compressor installed should cost about $800, and you wouldnt need to get rid of them when you do lift in the future.
Old Dec 24, 2008 | 10:06 AM
Wopstar's Avatar
Wopstar
Thanks for the info. I will check out the thread on lifts and see what it says. I used to work in a front end / alignment shop so I am familiar with many issues and extra work needed when lifting a vehicle. I will probably do the work myself and then take it to the alignment shop.
Thanks for the help.
Old Dec 24, 2008 | 10:49 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Just a question but why do you want to raise a 2 wheel drive truck?
