2004 back glass is leaking
Old Dec 22, 2008 | 11:42 AM
sf0606's Avatar
sf0606
I have a 04 fx4 extended cab and my back glass (solid, not a sliding back glass) is leaking on the passenger side corner. I searched the forum and found where some people were having issues with the sliding back glass leaking, but nothing where a solid one was. My question is this - - has anyone had any issues with the seal around the back glass or with the 3rd brake light seal causing you a leak?
thanks
scott
Old Dec 22, 2008 | 01:37 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
are you sure the back window itself is leaking?
the 3rd brakelight on the 04/05's is really bad about leaking. might want to give her a look first before fixing the back glass.
Old Dec 22, 2008 | 03:57 PM
sf0606's Avatar
sf0606
I talked with a mechanic at the Ford place and he told me if it was the brake light that the leak would be in the middle of the glass. He said that Ford has had issues with both the brake light and bad window seals causing leaks.
Old Dec 22, 2008 | 04:34 PM
damone's Avatar
damone
I have an 06' Screw. nIt had stains after first rain on rear set.
You can check the 3rd brake light by closing all windows and doors, then with the AC fan on full soak the outside of the light with real soapy water. If it is the light seal, there will be bubbles forming around the light, like mine did. Had the dealer erplace the seal.
Next rain storm had same leak stains on rear seat.
Dealer promptly replaced the window seal too. No more leak.
Old Jul 13, 2009 | 04:02 PM
Damon_Tirerack's Avatar
Damon_Tirerack
Former Vendor
Awesome idea! Mine's leaking as well so I will try this tonight.....
Old Jul 13, 2009 | 09:20 PM
mercman86's Avatar
mercman86
Mine was the 3rd light leakin. It was replaced under warranty, then it leaked again after i took it off to change a bulb. I have a cap on the truck now so i just removed it and used some silicone caulk on it and it hasn't leaked a drop since.
Old Jul 14, 2009 | 02:00 AM
FTE Trigger's Avatar
FTE Trigger
Tylus pointed out a few things that should have TSBs listed for both issues. You might be able to find the "factory" fixes in our TSB section above... if you want to tackle it yourself.
On Edit: I did find a TSB on a "Removal an Installation Tip" for the rear window...https://www.ford-trucks.com/tsb/full...hp?tsb=05-11-9
I think I saw the update (TSB) on the 3rd brakelight on the open forum...I'll have to check into that.
Old Jul 22, 2009 | 06:56 PM
Damon_Tirerack
Former Vendor
I took mine out and sure enough, there was signs of leaking all over. I had leftover 1/4" foam window sealer with adhesive on one side on from a door project on it. I did so I used that. Just strip the old gasket off, reapply a new one and put back in. Problem solved so far...
Old May 10, 2010 | 03:35 PM
Carnivore's Avatar
Carnivore
I have the same problem with my 04. Tried to use some silicone to seal it...
Old May 10, 2010 | 09:02 PM
Hummah Zach's Avatar
Hummah Zach
I've got that exact problem on my 04.. whats the fix?
bigf350sd
1947 and Older Ford Trucks
18
Oct 22, 2022 05:28 AM
Truckmano5
27
Feb 1, 2013 02:32 AM
nothercrash
21
May 25, 2011 07:59 AM
WeGoOn3
Oct 25, 2007 11:50 AM
bigric
Oct 13, 2004 09:51 PM
