3.5" Down Pipe
Old Dec 22, 2008 | 12:01 AM
cowmilker08's Avatar
cowmilker08
3.5" Down Pipe
Where can i one?
Old Dec 22, 2008 | 02:46 AM
immastrokinnow's Avatar
immastrokinnow
do you mean "where can you GET one?" beansdieselperformance.com made by tymar but i dont remember the website...
Old Jan 4, 2009 | 07:55 PM
cowmilker08
yeah thats what i meant. would that be a good size?
Old Jan 4, 2009 | 08:02 PM
c00nhunterjoe's Avatar
c00nhunterjoe
3.5 is a good size, slightly harder to fit then the 3 inch but the 3.5 i beleive is the output size of the turbo so it would be the ideal one. my opinion, if you are going to cram the 3.5 in there then buy the 4 inch and go all out!
3 inch pipe- Beans Diesel Performance - 94-97 7.3L Power Stroke MBRP 3" Down pipe (does not fit cat) (Powered by CubeCart)
3.5- still looking
4 inch- Beans Diesel Performance - 99-03 7.3L Power Stroke MBRP 4" Down Pipe (Powered by CubeCart)
Old Jan 4, 2009 | 08:04 PM
FARM69's Avatar
FARM69
Your going to have to do firewall work to get a 3 1/2 inch pipe in there. You might as well put a 4" discharge pipe on it if your already negotiating it.
Old Jan 4, 2009 | 08:07 PM
tjbeggs's Avatar
tjbeggs
I think 3 inch is the ideal size to be honest.The Super duty guys have the option of 3 , 3.5 and 4. Most of them stick with 3.5 but those that go straight to 4 inch complain of a power loss. In reality there isn't a power loss but your power band moves up a few hundred RPM so you "lose" low end torque. Unless your pushing over 500HP I don't think there is a need nor a benefit for anything bigger than 3 inch.
Old Jan 4, 2009 | 09:18 PM
cowmilker08
youve answered alot of my questions and never steered me wrong before tj so i'll go with a 3"
Old Jan 4, 2009 | 10:32 PM
Gobstopper909's Avatar
Gobstopper909
3.5- still looking
IIRC dale isley over at tymar performance has all 3 sizes with the option of ceramic coating. you just have to call for prices.
Future Home of Tymar Performance
Old Jan 4, 2009 | 11:07 PM
Vinford's Avatar
Vinford
What size is stock on there now? (1994)
My tailpipe is 3 1/2.
Old Jan 4, 2009 | 11:24 PM
Gobstopper909
stock vs a 3"x 3.5". the stock one is flattened between the firewall and tranny/block for clearance issues. diameter increases after tranny going to the cat.
Old Jan 5, 2009 | 12:20 AM
oldbird1965's Avatar
oldbird1965
I put the 3 1/2 in and had to do some serious body work. I read the above and its the first time, I've read on here, that bigger isn't better!
Old Jan 5, 2009 | 06:46 AM
tjbeggs's Avatar
tjbeggs
I think the Tymar 3 to 3.5 to 4 inch DP is a good option for get a big pipe in there but and using a straight 3.5 DP you may not notice any change but if you go up to the 4 inch you will notice the power band moving. I have not tried nor experienced it in someone elses truck I am just going off the reactions of Super duty owners so take that for what its worth. I have a turbo project in the works with a turbo that has a 5 inch outlet. It will be using a 3 inch DP.
Old Jan 5, 2009 | 07:08 PM
c00nhunterjoe
all of my schooling says that you need to match your outlet sizes. if the turbo outlet is 3 inch then use a 3 inch pipe, if the turbo outlet is 3.5 inch then use 3.5 inch... i would LOVE to see the 5 inch outlet.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
