hahaha, you'd like that wouldnt you. it is bragging rights. how many cummins owners can say that a cop admited that your truck was outrunning their cruiser......
well, katie will have to answer those questions to be exact but if i recall, the axle went first, she got stuck in a muddy spot or something and the axle let go after she got out and went up the road so they spent an extra day working on that, then the truck itself died. they had someone scan it and they said it had a cam sensor code and a pcm code in it. they installed a cam sensor from autozone but it is no good. the wire harness i can only assume got damaged when her fuel pump was replaced and just took until now to completly come apart.
yeah, in a nutshell that's the story. hey guess what, i have a fuel leak now! it never ends...but they look hot sitting in your driveway!! my baby doesn't get such high class company all that often, she's usually stuck between the expedition and the cummins!
i don't know...haven't had time to look too hard yet. you can smell it as soon as you get near her and in the cab on the road. if it is the new fuel pump...it should be under warranty including labor so i might cheat and run down to the oceanfront and have them look for me
