Computer Question..Help
Old Dec 21, 2008 | 05:24 PM
jetdoc's Avatar
jetdoc
Originally Posted by quaddriver
In the router.
usually 192.168.1.1 or 192.168.0.1 get to the router.
you dont say what router you have so I cant walk u thru it
I used the first one 1.1 and disabled the WEP No joy
Old Dec 22, 2008 | 01:53 PM
jetdoc's Avatar
jetdoc
Just got off the phone with India..oops I mean Verizon. She said that Fios is not supported by Windows 98...However I can hook it up to the router with a hard line and it works fine.
Old Dec 22, 2008 | 02:11 PM
donjamer's Avatar
donjamer
When entering the WEP password how many digits is it??
If it is 10 digits it is 64 bit encryption.. If it is more like 23 digits it is 128bit..
Maybe Win98 doesn't support 128 bit..
What are the settings that you are using??
Old Dec 22, 2008 | 04:40 PM
jetdoc's Avatar
jetdoc
It is 10 digits...64 bit I even turned off the WEP
Old Dec 22, 2008 | 05:01 PM
quaddriver's Avatar
quaddriver
ah, you didnt say win 98.....that changes things
is it SE? if its not SE, ferget it, if it is SE you have a chance. but you gotta run 64bit WEP
Old Dec 22, 2008 | 05:47 PM
jetdoc's Avatar
jetdoc
Sorry...How can I tell if it's SE....
Old Dec 22, 2008 | 05:50 PM
donjamer's Avatar
donjamer
Goto control panel
Select System
Should say windows 98 Second edition
Old Dec 22, 2008 | 07:23 PM
pfogle's Avatar
pfogle
Open the control panel, then the internet properties. Under the connection tab is an "automatically detect proxy setting" MAKE SURE that it's check box is marked. If not IE won't be able to find the DNS servers. Also make sure that when it connect the IP GATEWAY is correct. In your case it should be 192.168.1.1.
Old Dec 23, 2008 | 07:03 AM
jetdoc's Avatar
jetdoc
Goto control panel
Select System
it doesn't just windows 98
AMD k6 3d processor
64 mb of ram
Old Dec 23, 2008 | 07:08 AM
jetdoc's Avatar
jetdoc
The first box is checked
There isn't a box for IP GATEWAY...I've seen it before on this machine. I think my laptop is too old.
Old Dec 23, 2008 | 08:41 AM
donjamer's Avatar
donjamer
AMD k6 3d processor
64 mb of ram
Like Quaddriver said your SOL...
You can upgrade to SE, but probably not worth the aggrivation.. Just run it plugged in and live happily ever after..
Who knows maybe you will get a new laptop for Christmas..
Old Dec 23, 2008 | 09:06 AM
quaddriver's Avatar
quaddriver
Im surprised there is a win98 machine out there with a wireless card built in....
  #28
pfogle's Avatar
pfogle
Ok, the go into the wireless control panel and look at the status. If the IP address is 169.x.x.x then it's not getting an IP address from the router. What brand of wireless card are you using? Are the correct drivers and firmware installed?
F350-6
15
Mar 2, 2008 08:54 PM
cjben
20
Nov 13, 2007 09:25 PM
mymechanic'sanidiot
Feb 6, 2007 08:46 PM
dadsgreenpsd
Mar 14, 2006 08:52 AM
maticuno
Jan 20, 2005 06:45 PM
