I need some help. this is for a friend of mine. i am not very computer savvy. she is trying to use a router and hook up her laptop computer to the internet with her desk top computer. she bought a router,and the place she bought it from reassured her she had the right one. she went to put everything together,but noticed her desktop modem has a usb port with a cable running from it to her computer. the modem she bought doesn't have this port,and none she has found has the usb port. the modem she bought will not work because it does not have the usb port. Where can she get the correct modem or is there a way to hook it up without using the usb port? she is going to call the cable company(she has cable internet) monday and see what they say,but they will probably want an arm and a leg for one. any help is appreciated!! thanks.
What you need to do is install a network card into the desktop pc. They currently have the modem installed directly via the usb port. Internal network cards are cheap..
I assume this is an older pc without an internal network card.. But I would check to see if it has one already... They may have just taken the easy way and installed the USB...
Also I have seen where some people have both the USB and Ethernet cables connected to the modem and PC.. You only need 1 not both.. If this is the case just forget the USB one.
If I understand what she is trying to do and what the problem is here is a cheaper solution. Take the router back. With the return money buy a pci nic {network interface card} the pci is how it installs into the box. real easy to do. also buy a crossover cable. hook up both machine and run network wizard. She will have money left over.
For the life of me I dont know why she just doesnt just run wireless. It pretty cheap now.
Yea, what you really want is to be able to use a cat5 connection (the one that looks like a fat phone plug) out of the cable modem. Then you can put the router between the cable modem and the PC, and you can also plug the laptop into the router just like the PC. Connecting the laptop to the PC can be done and it will be easy to see the PC from the laptop and vice versa, but getting to the Internet that way will be a little more complex as then the PC has to do a couple other functions for you (DHCP, NAT,etc.)
That setup is probably what the salesperson who sold you the router assumes you had (cat5 rather than USB).
But the routers now do all that for you, they're designed to hook multiple computers to one cable modem/Internet connection. The advice to go wireless for the laptop is a good one too - if the laptop is fairly a new PC (or a Mac that's less than 10 years old!) its probably set up for wireless. The wireless router can be had for $50. That would be the same setup - router hooked to the cable modem with cat5. Desktop PC hooked to router via cat5...
Double check the cable modem, it may be connected via USB, but it may also have an RJ-45 connector. The desktop may also have the RJ-45 connector in the back, either built to the motherboard - in which case it will be clustered around the USB ports in the back, or as an add in card - in which case it will be in the add-in slots.
There are lots of correct answers above that all sound very different. I can try to make them a bit easier to understand.
RJ-45 = cat 5 = fat phone plug = Ethernet. Those are all pretty much the same thing. They all plug into that Network interface card, also called a NIC.
With the right settings you can either hook the modem into the router and use the router to split the signal between the computers, or you can keep the modem plugged into the USB port on the computer and get internet to the laptop from the desktop. That can be acheived either by a crossover cable between the Network cards on both computers or by plugging both computers into the router. Be careful though, the cat5 cable you use to plug a computer into a router is a bit different than a crossover cable you use to plug two computers directly together. The crossover cable has the send and receive wires flipped on each end because NI cards have incoming and outgoing connections that correspond to the opposite connection on the router. Kind of like an A end and a B end. In order to connect two A ends you have to flip the wires.
Simply put if I'm only running 2 boxes and their going to be wired I'm using a crossoverwire. It does'nt matter if you use 2-? boxes in order to connect them w/ a straight thru wire you have to have a hub/router to do so. So now you have 2 machines, a cable modem, a hub/router and 3 cat5 cables. You have to marry all this to each other and if something ever happens you got to trace it down.
Real simple a crossover between the 2 machines no powersources unlike the hub/router, run homenetwork wizard on the remote machine usse a usb flash and then run it on the laptop thats it. Running the network wizard sets the PC up to let the laptop getout on the internet thru it. If you ever have a problem its either in the wire or the 2 machines, then all you have to do is go to CMD type netstat and see if you can see the laptop and start tracing from there.
If you have the nics your looking at $15 depending how much wire you want. If you dont have the nics by the time you buy them and the wire you could have your freedom and gone wireless.
There's one limitation to this setup - you have to have the desktop machine running for the laptop to get to the internet. That may be an issue for some people, but not for others. Myself? Routers are so cheap nowadays, I'd go the router route (he, he) and keep them independent - especially if the laptop already supports wireless...
Agreed.
While I have at least 3 pcs running 24/7, I like the ability to take my laptop outside and sit in the shade and peruse the net, or, VPN to work and not be charged vacation!
Wireless is LOTS better than being 'leashed' by CAT5 cable.
Agreed. What I was saying If I was going wired I would use a crossover cutting out the extra cost of the hardware. If I was buying a router I would go wireless.
The host machine only has to be powered on not nessery logged on. I myself use wireless cause I dont sit at the same place all the time. I dont see the point in a laptop that is limited to just one spot in the house might as well just use the PC.
First thing is to make sure the network is functioning. Try to ping each machine *by IP address* from every other machine. If that's working, then Windows networking is having problems, which can be a mess to sort out.
