Door weather stripping?
Old Dec 19, 2008 | 11:33 AM
mndiesel's Avatar
mndiesel
I have a problem with my lower drivers door weather stripping. I just had back surgery and cannot get down there to check it out. It seems like the plastics holders that hold it tight to the door have broken(I guess). Can you just buy the plastic tabs or do you need to buy it as a package? Where can I get them? Thanks in advance
Old Dec 19, 2008 | 11:36 AM
mndiesel's Avatar
mndiesel
Sorry picture is a little out of focus. Had to take the picture holding the stripping with one foot balancing on the other. Anyway I think you get the idea.
Anyone fine the EDIT button for posts doesn't work???????
Old Dec 19, 2008 | 12:03 PM
just another truck's Avatar
just another truck
What happened to me hear is the door rusted away from the plastic anchors..I believe the weather strips there actually catch moister.. and in the end is worst for your truck
Old Dec 19, 2008 | 12:13 PM
mndiesel's Avatar
mndiesel
So how did you resolve the problem you had??
Old Dec 19, 2008 | 12:33 PM
just another truck
I pulled all of the stripping off, It is my hope that it will not get worse..
Old Dec 19, 2008 | 12:42 PM
triskit16's Avatar
triskit16
You can find an assortment of those plastic clips at the local parts store. I know Autozone used to carry a variety of them. I went and bought a whole new piece of stripping. It was like 17 bucks from the dealer believe it or not. It came with the lil clips and the stripping was a little different that original but it works!
Old Dec 19, 2008 | 01:42 PM
mechelement's Avatar
mechelement
If the weather stripping holds water in between itself and the bottom of the door, the use of 3M super weatherstripping adhesive and the clips would eliminate the water issue.
Old Dec 20, 2008 | 11:24 PM
mndiesel's Avatar
mndiesel
Thanks I will try that 3m adhesive.
Old Dec 21, 2008 | 12:28 AM
schlepprock250's Avatar
schlepprock250
The rear passenger side door rubber stripping(the bottom piece of course) was coming off, I used some black windshield sealant(not sure what the proper name is) and it has not come loose,its been about 4 months now.
Old Dec 21, 2008 | 08:36 AM
DieselCamper01's Avatar
DieselCamper01
A buddy of mine had to replace a couple of his because the clips were broken. They were relatively cheap. And his were a different style from stock also. My rear drivers side door has one or two bad clips that I am going to try and replace because the strip is in good shape still. Dealer for sure should have the clips. Or maybe I will use the weatherstrip adhesive I have. Hmmm? I would think either alternative would work great. Tom, if you need any help let me know. I am just up in Maple Grove.
Old Dec 21, 2008 | 10:37 AM
leekingen's Avatar
leekingen
i could come over to, maybe watch a littel football? lol
Old Dec 21, 2008 | 11:18 AM
cangim's Avatar
cangim
I found a rivet that fit in the existing hole and rivited mine on.
Old Dec 22, 2008 | 05:27 PM
mndiesel's Avatar
mndiesel
Thanks alot for offer your help,I truly appreciate that. I am not going to fix it till spring. I am up for meeting anytime you guys want. It would be nice to meet people from here and check out the trucks. Rep points awarded!!!
Old Dec 22, 2008 | 05:34 PM
leekingen's Avatar
leekingen
thanks-TOM-right back at you, call i'm in the big book. looking foward to a meeting to
Old Dec 23, 2008 | 09:54 AM
DieselCamper01
WE really should meet up. There is another member in Maple Grove also. Maybe after the New Year?
daddylee100
16
Mar 25, 2025 07:52 PM
JackTN
Mar 21, 2017 10:59 AM
jbourne84
Nov 14, 2016 07:37 PM
Trevin
22
Sep 9, 2016 08:41 AM
dagren99
May 28, 2012 01:41 PM
