Weatherstripping
Old Mar 18, 2017 | 05:12 PM
JackTN's Avatar
JackTN
Weatherstripping
I'm presently replacing the weather stripping in my '82 F100 Regular cab. All that is left to do is mount the inner weather stripping to the plastic door panel. The original brittle, falling to pieces weather stripping was stapled to the door panel. I do not have an upholstery stapler which is recommended in one place I saw. I want to tread carefully as these old panels can be brittle. Anyone ever tried pop riveting these strips on? The strips I bought have locating pins to help get positioned properly.
Old Mar 18, 2017 | 06:52 PM
FuzzFace2's Avatar
FuzzFace2
I am thinking you are talking of the "fuzzy" that is on the door panel that rubs on the glass? I will let other answer this that have done this but will also give something.
In the AMC world some have used metal mechanics wire in place of the staples and fold or twist in on the back side of the door panel.
They also used small screws to hold it in place.
For both use a small drill bit for the holes as needed.
Dave ----
Old Mar 18, 2017 | 07:16 PM
JackTN's Avatar
JackTN
Yes, I am talking about the "fuzzy stuff" even though mine is smooth rubber. Fuzzy stuff does seem fitting. I'm thinking the wire will be easier to remove versus rivets in case of mistakes (which are par for the course).
hharris8's Avatar
hharris8
I drilled small holes through it and the panel and used small screws as Dave mentioned. This worked very well. Just make sure tout the screws in the deep part so they do not rub the window.
Old Mar 18, 2017 | 07:19 PM
JackTN's Avatar
JackTN
Thank you. I now have some good feedback.
Old Mar 18, 2017 | 08:23 PM
FuzzFace2's Avatar
FuzzFace2
The car I was going by they are "fuzzy" on the door panel side and rubber on the out side that is why I said fuzzy.
That and mine were so bad they were in the bottom of the door in 1 inch long parts.
Good point on screws not hitting the glass.
Dave ----
Old Mar 18, 2017 | 09:06 PM
Gary Lewis's Avatar
Gary Lewis
I tried stapling to the panel using an air-powered stapler, and broke the door panel. Then I drilled holes and used aluminum pop rivets with washers. Did a very good job.
Old Mar 18, 2017 | 09:08 PM
JackTN's Avatar
JackTN
All of mine came out in pieces. Much of my plastic interior trim pieces were falling apart also. Went junk yard shopping and found a good donor truck. Years ago I was installing a rear speaker in my '66 Malibu. Needless to say I learned about the drill bit back glass conflict. Did not turn out well. My next attempt after the glass replacement involved placing a Sears catalog between speaker opening and glass. Big catalog is out of the question now because everything is digital.
Old Mar 18, 2017 | 09:20 PM
hharris8's Avatar
hharris8
Couple laptops?
Old Mar 21, 2017 | 10:59 AM
JackTN's Avatar
JackTN
That would work......
tab a
1997 - 2003 F150
Sep 10, 2016 07:27 AM
iszatso
Aerostar
Feb 12, 2015 10:21 PM
176ford
Apr 16, 2004 10:17 AM
Fal Grunt
Sep 25, 2003 12:20 AM
GB
Paint & Bodywork
Jan 31, 2003 07:21 AM
