4x4 noise, solid front axle
Old Dec 23, 2008 | 09:10 PM
  #46
Dave Sponaugle's Avatar
Dave Sponaugle
I can't imagine it having a CV joint, I am running a 92 D60 in my 86 with no CV, and have no issues at all.
I guess if I had it way up in the air, then a CV joint would help with the driveline angles, but not on a stock height setup.
Old Dec 23, 2008 | 10:07 PM
  #47
chewyjackson's Avatar
chewyjackson
I have no cv joint.
There is a wierd double u-joint set up, but that may be normal. I've never looked at one.
If I figured out how to do my own axle u-joints, I may just be able to figure this thing out and keep the truck.
That's part of why I love this old beast is that I can usually (with your guys' help) figure out how to fix stuff on my own.
Is this a specific transfer case that I am looking for, or are they pretty universal? Stamped or numbered anywhere?
Old Dec 23, 2008 | 10:10 PM
  #48
starmilt's Avatar
starmilt
IT will have the number on it I think 1356
Old Dec 23, 2008 | 11:19 PM
  #49
rupejosh's Avatar
rupejosh
i would imagine if you got the parts a buddy or two,a day and a couple cases of brew and youll be in tip top shape.
Old Dec 23, 2008 | 11:34 PM
  #50
starmilt's Avatar
starmilt
Myth quicker by yourself with no beer but not near as much fun.
Old Dec 24, 2008 | 12:14 AM
  #51
RCrawler's Avatar
RCrawler
I'm not sure myself. With a high pinion and length of the drivetrain, I don't see any cause for a CV. Maybe with the articulation of the straight axle over a TTB setup, Ford was afraid of binding?
Jason
Old Dec 24, 2008 | 12:16 AM
  #52
RCrawler's Avatar
RCrawler
Originally Posted by chewyjackson
I have no cv joint.
That would be the CV joint at the transfer case end of the front driveline. It is not a CV like you might see in a FWD car.
Jason
Old Dec 24, 2008 | 12:45 AM
  #53
chewyjackson
I just found this about a 2 hour drive away. On craigslist. Asking $180.00
Borg Warner 1356 transfercase 90 Bronco -Manual shift in good condition, full size Bronco. Just south of Coupeville in Admirals Cove on beautiful Whidbey island
Call Mike at 3606789195 or 3606226686 cell
Old Dec 24, 2008 | 01:14 AM
  #54
starmilt's Avatar
starmilt
Not sure but I bet you have a bolt on driveline and the bronco has a slip joint.
Old Dec 24, 2008 | 09:41 AM
  #55
Dave Sponaugle
Well looks like I called that one wrong since it does have a CV joint.
The most important difference in 1345 and 1356 Ford transfer cases is the output.
Some used slip joints, some used fixed yokes.
Look and see if your driveshafts unbolt at the transfer case end or if you unbolt the axle end and slip the yoke out of the transfer case.
Yours should be a Borg Warner 1356.
The ID tag should be on the rear of the case.
Here is a page with parts and pictures of one exploded and a little extra info.
1356 Transfer Case Parts Illustration!
danlyst13
Jan 31, 2015 10:58 PM
crobotti
Apr 9, 2014 10:35 AM
totin_tools
70
Nov 2, 2008 03:17 PM
pctjk
18
Feb 24, 2008 02:05 PM
