4x4 noise, solid front axle
Old Dec 19, 2008 | 12:36 AM
chewyjackson's Avatar
chewyjackson
I am getting a pretty loud grinding noise when the hubs are locked. It's 10 times worse when I engage 4X4.
I have the solid axle front. I don't know the axle code. 93 is stamped on the pumkin on the front.
My question is this....
Should there be any play in the u joint that connects the end of the axle to the hub?
When the hubs are free, I can grab the piece that goes into the hub and the other side that goes to the axle. I can actually wiggle it a little bit.
I only ask as it does it on both sides, but the noise seems worse on the driver side.
The follow up question becomes....how hard are they to replace????
Again, and as always, thanks in advance.
Old Dec 19, 2008 | 01:03 AM
rupejosh's Avatar
rupejosh
you should have no play.i am so glad you posted this a few guys on her have been pushin to get me to do an sfa swap because my d44 is doing the same exact thing on the same exact side.you should probably swap the u joints and the whole enchilada while your in there to prevent further issues thats what im gonna do.the u-joints shouldnt be too hard.if your ball joints are showing any wear whatsoever you may as well swap them while your down there.im doin bearings balljoints tie rods and u joints on mine real soon.let us know if ya need any info
Old Dec 19, 2008 | 09:03 AM
Dave Sponaugle's Avatar
Dave Sponaugle
If the ball joints are good, replacing the U joints will take some time, but not as long as it would to replace the ball joints.
Remove wheel, hub, pull axle shafts out and replace like a normal u joint.
Scroll down to see pictures of possible damage running it this way, about post 37 if I remember right..
https://www.ford-trucks.com/forums/8...th-my-4x4.html
Old Dec 19, 2008 | 10:41 AM
Franklin2's Avatar
Franklin2
How is this possible? I thought the solid front axles never broke?
Old Dec 19, 2008 | 12:57 PM
Dave Sponaugle
Everything wears out eventually.
Old Dec 19, 2008 | 02:52 PM
chewyjackson
Do you have to remove the knuckle to remove the axle?
Old Dec 19, 2008 | 03:32 PM
joe f350's Avatar
joe f350
yes u do i have to do the same thing
Old Dec 19, 2008 | 03:54 PM
starmilt's Avatar
starmilt
You should be able to remove the spindle and leave the knuckle in place.
Old Dec 20, 2008 | 01:34 PM
chewyjackson
Confirmed.
No need to remove the knuckle. Just remove the spindle, and that was andenture.
Old Dec 20, 2008 | 09:57 PM
Dave Sponaugle
So may we assume you are back in running condition?
Old Dec 21, 2008 | 10:15 AM
chewyjackson
NOPE!!!!!
I finished the driver side last night, pulled out of the garage to 3 inches of snow.
Headed down the road, the noise is the same, and now it's worse when I turn.
The U-joints definately needed to be done, but what's the next step????
I did not take the front diff cover off to inspect, I just removed the fill plug to make sure the fluid level was correct.
Wheel bearings also seemed fine.
If anyone has any suggestions it would be great.
Old Dec 21, 2008 | 11:15 AM
RCrawler's Avatar
RCrawler
Check the front driveline u joints and CV shaft. The noise could be migrating through the front end, sounding like it is at the wheel ends. Have you replaced the axle u joints on both sides?
Also, what was the condition of the spindle bearings inside the back of the spindle. The axle stub is supported by this bearing and can make noise like this if they are dry or worn out.
Jason
Old Dec 21, 2008 | 01:41 PM
chewyjackson
The truck is 30 miles away at work right now.
The splines all look ok, but I was suprised how easy they slid into the differential. Maybe I missed something on the re-install.
The needle bearings on both side u joints were absolutely shot.
I remembered one thing a few minutes ago. When I installed the driver side axle back in, as I rotated it, I felt a little grinding (this is with the wheels off and the front end lifted), when I spun the axle (by hand) when It was locked. I assumed a lack of lubrication, since it had been sitting that way for 2 days. That's why I double checked the fluid level.
The other thing was that it was snowing like crazy when I went on my test drive. I could of swore I heard a little squeeking noise, but there was so much snow on the ground, plows running, etc, that I don't know if it was in my imagination.
Old Dec 21, 2008 | 02:05 PM
Dave Sponaugle
That noise could easily be another U joint.
How are the driveshft joints?
With the front wheels off the ground on both sides and the transfer case locked in, the driveshaft will not turn, so the other side U joint will turn.
Unlock the transfer case, lock the other side hub and put the tire on the ground, now the drive shaft turns.
A bad u joint anywhere will be felt in the axle as you turn it.
Using the above process you can figure out where it is unless you have bad joints in both locations.
Old Dec 21, 2008 | 04:02 PM
starmilt's Avatar
starmilt
Did you service the needle bearings in the spindle while you had it apart these on most rigs get overlooked and never get serviced.
