Torque Converter Question
Old Dec 17, 2008 | 12:38 PM
60RatRod's Avatar
60RatRod
How can you tell if your Torque converter is bad as opposed to your tranny going out? I had a thread on clunking into reverse but winter weather has prevented me from looking at the problem right now. So I'm wondering if Im not going into reverse untill the rpm's get high and then she clunks into gear if it's a possible torque converter issue, Forward gears seem fine.
Old Dec 17, 2008 | 12:55 PM
Pocket's Avatar
Pocket
A delay shifting into reverse is normal. If I were you I would check the source of the clunking noise. It could be something as simple as a bad u-joint.
When the torque converter starts to go, you'll know it. The slippage will be felt in forward gears, rather than reverse. Reverse is normally the last one to die.
Old Dec 17, 2008 | 01:05 PM
60RatRod's Avatar
60RatRod
Its actually clunking into reverse because the RPM's are getting too high then fully engaging, Is there two reverse gears, because she creeps at first then clunks into place and then takes off good.
Old Dec 17, 2008 | 01:22 PM
rbaker6336's Avatar
rbaker6336
mine has done it every since the trans was rebuilt,I don't have the clunk but sometimes when I back up it starts backing then about a second later seems like it jumps into gear
as stated the clunk may be a u-joint or slip yoke
Old Dec 17, 2008 | 01:49 PM
60RatRod's Avatar
60RatRod
Hmmm, well it does still work, just noticebly different. I am leaning towards TQ because of the high RPM's like 2k and just 5 MPH. But heck I don't know. I think my 7.5K lbs trailer will be the big test.
Old Dec 17, 2008 | 02:03 PM
Pocket's Avatar
Pocket
The torque converter stays unlocked in lower gears, that's why it free-revs more in first and second gear. It won't lock until after the trans has shifted into 3rd. Once the torque converter locks, then you no longer have the free-revving feel.
However, a weak torque converter can slip too much when unlocked, and can even slip when locked.
Also, a torque converter can feel "grabby" when it's on it's last legs. What I mean by this is have the truck at a stop and in gear, then put the trans in neutral, and if the RPM's spike really high all of a sudden, then the torque converter is grabbing too much while in gear. The RPM's should hardly fluctuate when shifting from drive to neutral or park while stopped. Same goes when shifting from park or neutral into gear.
As for the reverse thing, it takes a good couple of seconds before it's fully engaged in reverse, so that part is normal.
Old Dec 17, 2008 | 02:19 PM
60RatRod's Avatar
60RatRod
Well I guess all is well, outside of the reverse clunking into gear, so I just need to investigate the clunk.
Thanks
Old Dec 17, 2008 | 04:40 PM
sneak's Avatar
sneak
Ok... that has me scared...
Old Dec 17, 2008 | 04:57 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
And, a good torque converter should make the truck eager to move. I remember after BTS did my trans, i was backing it out of the shop, brian commented how much pedal pressure i needed to keep it from backing up too fast, he said that the stock one wasnt anywhere like that, and damn he was right. Also, the torque converter doesnt lock in reverse. Numerous times ive bumped my switch getting into the truck, lock the TC and not know it, go to back up and throw it in drive, and the engine stalls. oops! Mine doesnt take "a good couple of seconds", more like <1
Old Dec 17, 2008 | 05:04 PM
60RatRod's Avatar
60RatRod
See here's the thing never had an auto trans truck before....I always thought you needed to apply some brake pressure when you put it gear mine isn't like that reverse or forward. Also on a hill when in reverse she just rolls back likes its in nuetral. backing up hill rev up to about 2K before she locks in gear and then it clunks in hard.
Old Dec 17, 2008 | 05:16 PM
PowerstrokeJunkie
Something internally is wrong. I bet you have alot of clutch material sitting on the bottom of your pan. Its a wonder it even moves still.
Old Dec 17, 2008 | 05:24 PM
60RatRod's Avatar
60RatRod
I emailed John Wood hope to get his opinion. No friction material in the bottom of pan (already pulled and looked) so I think the question is can it be repaired easily, being its only reverse. Hopefully something simple like a snap ring or loose bolt because the rest of the tranny works fine.
Old Dec 16, 2009 | 05:45 AM
ford4x4s's Avatar
ford4x4s
i had a 97 powerstroke that i thought the tranny was bad, reverse actually would have two speeds and forward gears were all over the place and would slam into gear. tranny seemed confused. wouldnt happen all the time though. turned out that if i would wiggle the wire harness on tne transmission tranny would be perfect again. i did it for 30k miles,sold truck and new owner been doing it for a year. seemed to do it more freqently on hot days. hope this helps somebody
Holehawgg
Jul 11, 2014 06:05 PM
stlrisk
Aug 6, 2010 05:29 AM
SOB Racing
May 7, 2008 12:50 PM
CTford
Feb 3, 2006 02:48 PM
Trucky18
1978 - 1996 Big Bronco
May 31, 2003 09:41 AM
