Fuel pump filter?
Dec 14, 2008 | 09:45 AM
Fuel pump filter?
1999 Ford F250 7.3L powerstroke - Is there a filter or screen between the fuel tank and the electric pump?
Dec 14, 2008 | 09:48 AM
Inside the fuel tank is a pair of mixing screens which may become clogged. Below that is a coarse screen on the bottom of the pick up tube.
If you do the Hutch mod you will get rid of those pesky mixing screens. You can put a vac gauge between the tank and fuel pump to determine if the screens are clogged.
Yes. Right at the pump's inlet. This is in addition to the screens mentioned above.
Pop
Dec 14, 2008 | 10:08 AM
Thank you to both answers!! Can you point me to the Hutch mod? I did a search and come up with hundreds of hits but I still can't find it.
Dec 14, 2008 | 10:11 AM
Dec 14, 2008 | 10:21 AM
Dec 14, 2008 | 05:33 PM
Quote:
Originally Posted by
SpringerPop
Pop
I didn't know there was anything at the pump inlet. Is it actually in the orifice and only accessed by removing the fuel line?
Dec 14, 2008 | 06:15 PM
Yeah, it's just a screen at the pump inlet. Not a filter per se.
Dec 14, 2008 | 06:23 PM
Kwik found it when he had his apart.
Pop
Dec 14, 2008 | 06:43 PM
you do have to drop the tank for this correct?
Dec 14, 2008 | 07:37 PM
Is it best to remove the screen to prevent a problem? If so, do I just remove the fuel line from the pump and pull the screen out with a pick?
I'm not too worried about any trash getting into the pump as I have a Dahl pre-filter.
I'll be playing under the truck tomorrow anyway, dropping the tank to replace the fuel sender
Dec 14, 2008 | 07:47 PM
It's part of the pump, there's no way to remove it unless you wanted to try to drill it out.
rockittsled
Feb 20, 2014 09:13 PM
abe
Jul 21, 2013 10:13 AM
Jaaaaaaackman
Sep 17, 2006 07:19 PM
hink10
30
Feb 23, 2006 12:47 AM
mauicruza
1966 - 1977 Early Broncos
13
Feb 10, 2005 05:37 AM
