VGT Turbo Help
Old Dec 15, 2008 | 09:54 AM
gvandyke's Avatar
gvandyke
I could not go faster than 10 mph so I had it towed to the dealer. Hopefully I will hear something today.
Old Dec 15, 2008 | 02:14 PM
gvandyke's Avatar
gvandyke
I just got a earlyier from the dealer and was told the ICP sensor and harness was bad. I just got a call back and now the HPOP is bad.
Old Dec 16, 2008 | 10:15 PM
coltrw's Avatar
coltrw
gvandyke:
Pretty much the same symptoms I had when my HPOP went south. Same description form the tech that worked on my 03 F250 as well. It was throwing a P1285 (think it was P anyways) code that indicated ICP out of range low. ICP was replaced (not at dealership), and soon after I had no boost and no power on throttle. I also experienced extended cranks when attempting to start while engine was at op temp.
I thought it was just the ICP pigtail connector that was messed up (the person who replaced ICP the first time did a crappy job on splicing the pigtail connector). Dealer's tech started with ICP and worked the diagnosis until all signs pointed to HPOP. About $2500 later, we were good to go.
Haven't had any problems since, with the exception of decreased fuel milage. I was at about 20-22 mpg on highway before HPOP was replaced. I'm down to beween 16 - 18 mpg nowdays (but I think it has to do more with the fuel we have right now more than anything). And I'm still not complaining too much about that.
Here's the only other thing I would suggest, cause I'm not sure if you've done this yet. Given that you have ARP studs installed you very well may have gotten around to these. If you're getting HPOP replaced, have the tech take a look at the oil cooler filter screen and see if it needs replaced. If HPOP is coming out, that shouldn't be too much more effort to look at. I had some earlier issues with the oil cooler failing (causing oil to contaminate coolant) and that might be worth checking while the engine's apart.
Old Dec 18, 2008 | 09:09 PM
gvandyke's Avatar
gvandyke
Well, I got my truck back today. They replaced the ICP Sensor and harness and the Fuel Injection Pump. Truck is running great and is retuned to the Spartan ASE tune.
My Baby Is Back.
Old Dec 18, 2008 | 09:18 PM
bismic's Avatar
bismic
Glad you have your truck back! Was the HPOP actually bad or was it a false alarm?
Old Dec 18, 2008 | 09:24 PM
gvandyke's Avatar
gvandyke
When I was called on Monday I was told the HPOP. But the paperwork says Fuel Injection Pump. I guess the service writer was not sure. All I know is it is 100% better than the last time I drove it.
Old Dec 19, 2008 | 11:31 AM
gvandyke's Avatar
gvandyke
<TABLE cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD><TABLE cellSpacing=2 cellPadding=1><TBODY><TR><TD>I just found out that the Fuel Injection Pump and the High Pressure Oil Pump are one and the same. Here is the Ford part #3C3Z9A543AARM.</TD></TR></TBODY></TABLE></TD><TD></TD></TR></TBODY></TABLE>
Old Dec 19, 2008 | 11:39 AM
patrickke's Avatar
patrickke
did the dealer ream you real bad or was this fairly inexpensive?
Old Dec 19, 2008 | 12:51 PM
1979Mustang's Avatar
1979Mustang
What dealer did you take your truck to? I see you are not that far from me. I got my F-350 from Atchinson Ford and it runs awesome!!!!
Old Dec 19, 2008 | 12:56 PM
gvandyke's Avatar
gvandyke
I went to Russ Milne Ford. My truck goes there or Romeo Ford. Russ Milne is close and I know the diesel tech at Romeo. Both have taken good care of my truck.
Old Dec 19, 2008 | 09:24 PM
gvandyke's Avatar
gvandyke
Out the door was $1800.00. The HPOP was $593.00, the ICP Sensor was $141.00, the ICP Connector was $89.00 and a $13.00 gasket. The rest was labor.
FastTimes10
May 19, 2016 10:11 AM
Octoberskys20
16
Feb 8, 2016 01:36 PM
mrm8174
25
May 1, 2015 10:08 PM
Skipper 7886
Apr 10, 2011 11:24 AM
gaer
Mar 13, 2011 10:54 AM
