Need Help
Old Mar 11, 2011 | 08:39 PM
gaer's Avatar
gaer
Need Help
no power, poor rpm on 2003 6 litre
turbo wines, motor will only turn up just over 2000 rpm. i had a bad injector and a stuck turbo. i changed the injector, cleaned the turbo and still no change. cleaned the vct control valve and ebr valve(with carb cleaner) i brought it to the ford dealership and had it hooked up to computer and they said all injectors are running fine and good turbo pressure, i have all the latest updates and had code poo46(turbo boost control solenoid) did a performane test and it was ok. they found ebp sensor too high (indicating plugged exhaust). i took the exhaust off before the cat and still no change, put a new ebp sensor on and made sure piped clean, still no change. if i plug the vct control valve the turbo will open up and the motor will red line. now why wont my computer control the vct or do i have other issues? thanks in advance for any advice!
Old Mar 12, 2011 | 01:40 PM
Racerguy's Avatar
Racerguy
Welcome to FTE
I've moved your question for you to the 6.0L specific forum.
The guys here should be able to help.
Old Mar 12, 2011 | 02:10 PM
bismic's Avatar
bismic
Do you have any mods? Have you checked your MAP sensor hose for plugging?
Old Mar 12, 2011 | 06:58 PM
wulfman's Avatar
wulfman
I think i read on here you are not supposed to clean the VGT control valve. Maybe that could be problem JMO
Old Mar 12, 2011 | 07:01 PM
bismic's Avatar
bismic
Good catch - it is possible to damage it when cleaning it!
Old Mar 12, 2011 | 11:27 PM
BobsF350's Avatar
BobsF350
bad turbo seal?
if you mat the pedal itll only go to 2000?when you do this does it smoke like a biiiitch out the ex pipe?
Old Mar 13, 2011 | 10:54 AM
gaer's Avatar
gaer
when I step on the pedal , very little smoke. Just checked the MAP sensor,looks clean,after I cleaned the VCT control valve,Ford did a performance test and said it was working fine. Only mods I have is a 4 inch exhaust.rest is all stock. Ford also said I have full turbo boost.
jokerj280
Dec 25, 2016 07:59 PM
thecaptincole
Oct 6, 2016 10:01 PM
josher66666
Dec 25, 2014 07:18 AM
Mich6.0
Aug 29, 2012 11:29 PM
tony2fingers
Jun 30, 2009 07:14 AM
