4wd conversion
Old Dec 10, 2008 | 12:03 AM
mrwrench's Avatar
mrwrench
4wd conversion
what are the best axle and transfer case combination to make a 2002 4x4 ?
are all the front axles same with manual hubs?
thanks
Old Dec 10, 2008 | 12:08 AM
4inchlovin's Avatar
4inchlovin
Dana 60 in the front with warn manual locking hubs... While your at it u might as well put a strong limited slip or locker in the axle too....
Old Dec 10, 2008 | 12:13 AM
mrwrench's Avatar
mrwrench
what is on the flight (or something like that) transfer case?
Old Dec 10, 2008 | 12:17 AM
4inchlovin's Avatar
4inchlovin
On the fly transfer case is one that can be shifted into 4wd while moving... The best transfer case ever built is a NP205. They came in chevy's in the late 70's early 80's. it is not a shift on the fly transfer case. BUT it is the strongest and best built. You would have to make a call to Advanced Adapters to get that transfer case working behind your ford transmission.
Old Dec 10, 2008 | 09:33 PM
mrwrench's Avatar
mrwrench
is the on flight available in 2002 /2003 f250?
Old Dec 10, 2008 | 09:44 PM
Ponyboychris's Avatar
Ponyboychris
The OEM transfer cases that came with the stock trannies (auto and stick) on superduties have the ability to shift on the fly as well - in case you were wondering.
Old Dec 10, 2008 | 09:50 PM
mrwrench's Avatar
mrwrench
yes, thank you
Old Dec 10, 2008 | 09:59 PM
Ponyboychris
Cool, are you converting a 4x2 to 4x4 or beefing up an existing 4x4???
Old Dec 10, 2008 | 10:45 PM
mrwrench's Avatar
mrwrench
if I dont sell it , I will convert my 2002 2wd in 4x4.
all the suggestions will be appreciate
nstueve
Jan 3, 2014 03:11 AM
oldfords4ever
Feb 8, 2011 09:30 PM
Driscol
20
Dec 3, 2007 03:47 PM
BlueKnight
Mar 4, 2005 11:54 AM
gate9797
Jan 29, 2005 09:52 AM
