Front Axle
Old Jan 11, 2005 | 06:28 PM
oldfords4ever's Avatar
oldfords4ever
Front Axle
what is the best replacement front axle to upgrade a '64 F250 4x4 to disc brakes?
Old Jan 11, 2005 | 07:58 PM
barry's Avatar
barry
Use an axle out of a 76 or later F-250 4x4. They are set up with disc brakes. Just make sure you get the same ratio as you have now.
Barry
Old Jan 11, 2005 | 08:05 PM
oldfords4ever
Barry,
Thanks for your help.
Andy
Old May 12, 2010 | 04:21 PM
BlueOvalBud's Avatar
BlueOvalBud
I know this is an old thread, but I have a question...
My truck is a '64 F250 4x4.
Is a '76 -'79 front axle a direct bolt-in swap into a '61-'64 F250?
I know the frame from 65-79 is the same, so is the '61-'64 frame different?
I understand about matching gear ratios, otherwise parts will start flying!
So my biggest concern is the steering setup. Will the manual steering work? Or will I have to do some type of power steering swap so the drag link setup will work? I do like manual steering and non-power brakes (less stuff to worry about breaking).
I'd like to upgrade the axles to the 77-79 style so parts will be easier to find. Dana 60 front axle would be nice to match the Dana 60 rear axle. I think OX cable lockers would be a nice way to get good traction devices, and a nice lever could be made to be '64 era appropriate in style.
Imagine the 4 speed lever, transfer case lever, PTO lever, Dump bed lever, and the Front and Rear axle lock levers could be custom-made to match in witht he interior with neat shafts and cool *****.
Old May 12, 2010 | 10:12 PM
garbz2's Avatar
garbz2
Or use one of these
4x4 Front Differential Disc Brake Kits
Garbz
Old May 13, 2010 | 03:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The F250 4WD frames are not all the same. The width between the rear frame rails (behind the cab) changed in 1977, after the High Boys were canceled.
1961/72 F100/350's have 33 1/2" rear frame rails, as do 1973/76 F250 4WD's and 1977 F250 4WD's assembled before serial number Y20,001.
From serial number Y20,001, there are no more High Boys, the width between the rear frame rails grew 4" to 37 1/2"
The front half of the frames are the same width 1961/79.
ALL 1973/79 F100/350's have 37 1/2" width rear frame rails except the High Boys and F350 Regular Cab Styleside Trailer & Camper Special's on the 140" wheelbase.
Old May 24, 2010 | 01:06 PM
Elvis40's Avatar
Elvis40
Resurrecting this thread again, how might a swap be done with a coil sprung 66 4wd truck? Will that same disc brake conversion kit work on this axle as well?
Old May 24, 2010 | 03:04 PM
garbz2's Avatar
garbz2
You would need the five lug 44 conversion.
Garbz
Old Feb 8, 2011 | 07:46 PM
joshua29's Avatar
joshua29
joshua29
some of the most durable trucks ever made..and in my opinion the most beautuiful...
Old Feb 8, 2011 | 09:30 PM
63' f100's Avatar
63' f100
Thanks for the input....
akpolaris
Jun 20, 2016 04:11 AM
nstueve
Jan 3, 2014 03:11 AM
Owen Bacon
Jul 23, 2013 08:17 AM
Powermonger
Sep 29, 2011 06:35 AM
