axle code question
Old Oct 22, 2007 | 03:23 AM
Driscol's Avatar
Driscol
axle code question
F250 4x4 with an axle code of B4J and another F250 4X4 with an axle code of 37R? Whats the better axles and is it worth a swap. Any idea of the gear ratio on the 37R? Thanks
Old Oct 22, 2007 | 05:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Rear axle code B4 = Dana 60 / 4.10-1 / Limited Slip / 5300 lb. Rear Axle Capacity
Front axle code J = Power Steering
37 = Dana 60 / 3.54-1 / Non Limited Slip / 5300 lb. Rear Axle Capacity
The R front axle code relates to what 4WD front axle type was used. There are two different front axles, depends on the year model the axle was used on.
Old Oct 22, 2007 | 10:53 AM
Mil1ion's Avatar
Mil1ion
In your case R stands for power steering on a truck with a 3500 lb Dana 60 Front axle.
Old Oct 22, 2007 | 01:50 PM
Driscol's Avatar
Driscol
HI Dennis. I found a few links to punch in codes. According to that and a few other members in a different thread the front is the optional 4500lb PS. In all fairness to you though they had the option of seeing the entire VIN. Does that mean it's just beefier? Is it a recommended swap for a Dana 3500 lb standard with 410s? If it's more trouble than it's worth I'll just list it in the parts forum. Thanks
Old Oct 22, 2007 | 03:14 PM
NumberDummy
Parts catalog sez: R =
1975/77 / Dana 44-6CF, 60F Front Axle / 3800 lb. Front Axle Capacity / Power Steering
1978/79 / 4500 lb Front Axle Capacity / Power Steering
Old Oct 22, 2007 | 03:17 PM
Driscol's Avatar
Driscol
That fits Bill. This R is out of a 78 F250. Is it still a Dana?
Old Oct 22, 2007 | 05:12 PM
NumberDummy
That's all the parts catalog sez for the R code in 1978, but a Dana it is.
Old Oct 22, 2007 | 08:59 PM
Mil1ion's Avatar
Mil1ion
sorry biut that .. My 3 instead of a 4 was a typo.
I didn't see the mistake until now
got to this page and scroll down to just about the bottom to see what decodes to what.
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Old Nov 13, 2007 | 06:10 PM
gscottc's Avatar
gscottc
Can anyone supply a link to an axle code decoder / definition list for a 1975 f-250 ?
Old Nov 13, 2007 | 06:44 PM
Mil1ion's Avatar
Mil1ion
We have all the info here.
just post the code (s)
There are only a few occasions when the codes are not application from year to year.
Old Nov 13, 2007 | 11:36 PM
gscottc's Avatar
gscottc
Axle code from the door plate = 22J = DANA61 + power steering, right?
The tag on the rear differential itself is stamped:
EDI D5TA NHA
603438 - 6 3 07,
Does the differential tag coincide with the door plate?
Old Nov 14, 2007 | 01:08 AM
Mil1ion's Avatar
Mil1ion
Yes it does.
Old Nov 14, 2007 | 11:29 AM
gscottc's Avatar
gscottc
O.k. thanks! So it's a DANA 61 3.07. Apologies for my ignorance but isn't a gear ratio of 3.07 relatively high, and thus better suited for highway fuel economy than towing?
Old Nov 14, 2007 | 11:34 AM
NumberDummy
Better for high speed driving and fuel economy.
Towing: Uh..it can do that too, but you'd better hope that GREEN light is a long one.
Old Nov 14, 2007 | 12:14 PM
gscottc's Avatar
gscottc
Can we dig a little deeper into the "so what"? Given the high gears (75' 2wd F-250 390 4v C6) and that having the C6 rebuilt is next on the to-do list (and much more likely than changing rear diffs in the near term) and that I do need to do some towing (primarily freeway), is there any modification I should have done to the C6 to improve the towing characteristics of this otherwise fine truck?
