What year C6 do I have?
Old Dec 8, 2008 | 04:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 1974f250
The dipstick only says check while hot in idle. Someone has scribed "full" below the "add" mark. I will look under it tomorrow for more numbers.
For the tilt it definitely pushes away for it to tilt.
I'm not gonna argue over the tilt wheel jazz, I haven't owned a 70's truck since 1988, and the parts catalog illustrations don't show how it operates.
AlI I remember from the 60's T-Birds I've owned...you pulled, not pushed.
Old Dec 8, 2008 | 10:08 AM
masterbeavis's Avatar
masterbeavis
The truck tilt wheels ya pushed, at least that's what i want to remember.
If you look in the opening for the column, if you see a steel vertical bar directly behind the signal arm, you are a tilt wheel. If somebody trys to sell you a tilt wheel without that extra bar, ask for a demonstration.
Old Dec 8, 2008 | 11:17 AM
NumberDummy
You can still buy the tilt wheel parts from Ford as they are the exact same ones the 1970/79 cars used.
The CrownVics/Grand Marquis/Town Cars used the same parts thru the 1980's.
The locking lever (E2TZ3B661A [was DOAZ-A]-curved part with teeth) is the piece that usually fails.
Roelito78
52
May 11, 2020 08:51 AM
460 FORD MAN
27
Jan 28, 2015 11:47 AM
bull jr
Sep 30, 2014 08:27 PM
warvet1973f100390c6
Oct 9, 2013 02:44 PM
WoodN1_76
May 11, 2003 01:56 PM
