2 Dipsticks??
Old Aug 8, 2012 | 08:55 PM
460 FORD MAN's Avatar
460 FORD MAN
2 Dipsticks??
I got a 79 f150 4x4 shortbed, 460 c6 trans. This may be a stupid question but, why do I have two dipsticks? The 'normal' dipstick for oil is on the driver's side coming from the oil pan. The second dipstick is on the front of the motor on the passenger's side. It is short like it has been broken off or something so it doesn't read anything.
Thanks
Old Aug 8, 2012 | 09:03 PM
460 FORD MAN
It's circled in red..
Better view of where it goes..
Old Aug 8, 2012 | 09:08 PM
kevin316's Avatar
kevin316
the original dipstick was in the timing cover. Someone probably put on an after market oil pan with the dipstick in it. I have heard some people say they do this because the stock one has a habit of popping out when they are driven hard. That and the only aftermarket dipstick I could find was like $70.
Old Aug 8, 2012 | 09:11 PM
OldStyle's Avatar
OldStyle
Rusty Roller
The motor came out of a car thus the front dipstick. When into a 4x4 and received a different oil pan.... and .... those have a dipstick. so now you have 2. Sounds like the front one was cut to avoid bottoming out in the new pan and is used as a plug.
Old Aug 8, 2012 | 09:21 PM
J ballan's Avatar
J ballan
My 400 was the same way. It was a case of a older 400 out of a car with the original 79 oil pan from the truck.
Old Aug 8, 2012 | 09:24 PM
kevin316's Avatar
kevin316
Don't agree. I have a '78 F150 2wd with a 460 and the dipstick is in the timing cover. I know the engine is original.
Old Aug 8, 2012 | 09:38 PM
460 FORD MAN
Ohh okay, that makes sence! Thanks guys!
Engine original with the truck?!? I thought they didn't come with 460's untill 80 something.
Old Aug 8, 2012 | 09:53 PM
410F-100's Avatar
410F-100
4wd dident come w/ the 460s
Old Aug 8, 2012 | 09:55 PM
460 FORD MAN
Ah, got ya. I learn something new everyday.
Old Aug 8, 2012 | 10:05 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Cars and 2wd trucks use a front sump pan, hence the dipstick in the timing cover. 4wd trucks use a rear sump pan, so the dipstick needs to read from the rear, and going thru the side of the pan was the easiest way to get there.
FWIW, the 83+ trucks also use a rear sump pan, 2wd or 4wd.
Old Aug 8, 2012 | 11:12 PM
bamaf150's Avatar
bamaf150
I have a 360 with 2 also, same deal, motor came from 2wd, 4x4 has rear sump....
Old Aug 8, 2012 | 11:17 PM
bamaf150's Avatar
bamaf150
Thats what was said; 2wd has front sump, dipstick in timing cover, 4x4 has rear sump, dipstick in pan towards rear.
Old Aug 9, 2012 | 06:54 AM
OldStyle's Avatar
OldStyle
Rusty Roller
and those too.... You posted while I was typing
Old Aug 9, 2012 | 11:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 460 FORD MAN
Engine original with the truck?!? I thought they didn't come with 460's until 80 something.
460: 1968/78 Lincoln/Continental Mark III, IV, V / 1972/76 Thunderbird / 1973/78 Ford/Merc Passenger Cars / 1973/76 F100 / 1973/79 F250/350 / 1975/79 F150 (1979 except CA) / 1975/97 E250/350 / 1982/97 F250/350.
460 not available with a M/T or 4WD until 1983.
Old Aug 9, 2012 | 11:56 AM
bertha66's Avatar
bertha66
I just put a pug in the timing cover and use the one in the pan. I did use a car engine in my 76 F250 4x4 and put a rear sump pan on it.
