Sponsored by: Kumho
BROKEN STABILIZER MOUNT
Old Feb 4, 2002 | 03:07 PM
FNX4WLR's Avatar
FNX4WLR
:I HAVE A 2001 F250 PSD CC 3" LEVELING KIT 41,000 MILES. PROBLEM IS,MY STEERING STABILIZER MOUNT BROKE IN HALF! I HAVEN'T EVEN DONE ANY SERIOUS FOUR WHEELING. HAS ANYONE HAD THIS PROBLEM/IS THIS COMMON? DID WELDING AND REENFORCING WORK. FORD WANTS $895. JUST FOR A NEW PART (WHOLE NEW AXLE HOUSING!)-X09
FNX4WLR
Old Feb 4, 2002 | 09:07 PM
orange peel's Avatar
orange peel
if i were you i would take to a certified welder or at least someone you trust enough to weld that and have it welded back. not sure how much pressure gets put on it, you might want it reinforced.
Old Feb 4, 2002 | 09:16 PM
Ford79's Avatar
Ford79
Please do not post in all caps, it is just like yelling. And it's hard to read. Thank you, Mike.
Old Feb 4, 2002 | 10:40 PM
FNX4WLR's Avatar
FNX4WLR
Post BROKEN STABILIZER MOUNT
sorry, thanks for the HELP mike.
Old Feb 5, 2002 | 09:28 AM
Ford79's Avatar
Ford79
I can't see why they would have to replace the whole axle housing. Take it to a welding shop and have them fix it.
Old Feb 5, 2002 | 08:13 PM
destiny88's Avatar
destiny88
I do not do a lot of 4 wheeling myself but my bodys do. I am just wondering if the 4 wheeling you have done is choppy, or has a lot of turns. The reason I say tis is because on my dirt bike if you run a lot of sand, staight lines you can run a stabilizer. If you run a track you can not. When you do choppy quick turns there is a lot of stress on a stabilizer. I would weld it on but when you reinforce, as I have learned from my friends, make sure not to over reinforce in one spot. When you build it up thicker and bulkier are not better. Do not run braces thicker than what you are welding too, and run them as far as possible. Thats my the axle in my quad is 1 1)2 at the carrier and about an inch at the hubs. The taper causes the axle to have as much stress at the anchor point as at the wheel.
Old Feb 7, 2002 | 07:50 PM
FNX4WLR's Avatar
FNX4WLR
destiny88
thx for the reply. i've had 4x4s for for 12 years (4 all diferent brands)... with stabilizers. i've only had to replace one. when i four wheel it's usually slow and easy so i don't think terrain is my problem. besides the location of the break doesn't receive much stress due to the stabilizer. the break is above the stabilizer. if anything force from the swaybar/tracking bar (whatever it's called) is what would have broken it.
fnx4wlr
Old Feb 8, 2002 | 12:00 PM
weldman's Avatar
weldman
fnx4wheeler
Sep 19, 2013 01:10 PM
fnx4wheeler
Aug 31, 2007 05:37 PM
fnx4wheeler
Jul 21, 2006 07:28 AM
FNX4WLR
13
Aug 26, 2002 06:34 PM
FNX4WLR
Aug 26, 2002 05:38 PM
