Another AC Venting question?
Old Sep 18, 2013 | 05:13 PM
fnx4wheeler's Avatar
fnx4wheeler
Okay, searched around but could not find posts that described my problem. My Max AC does not blow out my dash vents as strongly as when my switch is set at AC (normal). Said another way, AC is blowing stronger than Max AC through the dash vents. I have cold air and a good fan. Any ideas? Vacuum line, bad blend door? Is the recirc/max switch control the blend door or is it a seperate door? Thank you.
Old Sep 19, 2013 | 01:08 AM
fnx4wheeler
btt anybody?
Old Sep 19, 2013 | 01:34 AM
jgilrfr's Avatar
jgilrfr
im having the same problem so ill be watching for any advice also
Old Sep 19, 2013 | 02:06 AM
BigAlsPSD's Avatar
BigAlsPSD
Make sure that you don't have a plastic bag sucked up into the recirculate area below the glovebox. You'd be surprised how far they can get sucked up there.
If that's all clear, check the vacuum lines and actuators for the max a/c door.
Old Sep 19, 2013 | 12:02 PM
fnx4wheeler
DING DING BigAl you are a winner! I did get new vacuum lines to my hubs out of the deal. Didn't fix so I was looking at the lines on the passenger side interior fire wall. Low and behold what this little white thing up here... a plastic grocery bag! Thanks for the reply.
Old Sep 19, 2013 | 01:10 PM
BigAlsPSD's Avatar
BigAlsPSD
Great, we all like easy and cheap!
trike1946
May 23, 2018 08:08 PM
50f6
Jul 1, 2016 05:09 PM
bcjim
1983 - 2012 Ranger & B-Series
Apr 21, 2005 11:29 AM
Alan Szabo
1997 - 2003 F150
Jul 4, 2003 04:33 PM
