Sponsored by: Kumho
skyjacker lift
Old Jul 31, 2002 | 10:50 AM
FNX4WLR's Avatar
FNX4WLR
skyjacker lift
Old Aug 12, 2002 | 12:22 PM
bobtechnologies's Avatar
bobtechnologies
skyjacker lift
hey, i ordered a 6 inch skyjacker for my 96 2wd f-250, i got the package that includes skyjacker shocks. does anyone have any opinions on these? i think they should be decent. also, any advice on installing the lift kit? also, if anyone has done a 6" lift on this type of truck can you tell me what size tires you could fit. I was going to order 36s for it, but i dont really want them to rub.
any help is appreciated
Old Aug 23, 2002 | 10:00 PM
bad 78 f 250's Avatar
bad 78 f 250
skyjacker lift
i have a 4 inch skyjacker lift on my 78 f 250 i have the nitro shocks i love it i think you will be satisfied with the lift kit. i never did a lift on a 2wd so i cant help you there bad 78 f 250
Old Aug 23, 2002 | 10:23 PM
MustangGT221's Avatar
MustangGT221
skyjacker lift
The shocks are good, and you shouldn't have a problem with rubbing, how wide are they though?
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Old Aug 25, 2002 | 09:09 AM
AZ4x4f150's Avatar
AZ4x4f150
skyjacker lift
The shocks are pretty decent the lift it self isn't that hard to install just be patient and double check everything after you install everything if you're doing it yourself.
As for the tires rubbing it is going to depend on how wide of a tire and rim you're going to use and the back spacing of the rims
Old Aug 26, 2002 | 01:44 PM
rabidranger's Avatar
rabidranger
skyjacker lift
Just make sure you actually do the recommended re-torque of all u-bolts after about 50 miles, and again at 500. Mine all took another 1/4 turn!
Old Aug 26, 2002 | 05:38 PM
hotrod1783's Avatar
hotrod1783
skyjacker lift
I have a 97 F350 4x4 with a skyjacker 6 inch lift. The shocks work great and give a good ride. I run 35x12.5x16.5 BFG all terrains on a 8.5 inch rim. I have plenty of clearance with the exception of the front of the front tires to the bumper. You will have to check that to ensure that a 36 inch tire will not hit. Hotrod 1783
97 F350 4x4 6 inch lift 35 inch BFGs and ofcourse a Powerstroke
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
