Battery heat shield????
Old Dec 5, 2008 | 09:50 AM
jmbaker3's Avatar
jmbaker3
Replaced my batteries recently and the cover ( heat shield?) going around the battery on the passenger side needs replacing. Have no idea what the official name of this part is... can someone tell me so I can look up for a replacement.
Thanks.
Old Dec 5, 2008 | 12:44 PM
katiesdad7's Avatar
katiesdad7
According to the shop manual it's called a battery cover.
https://www.motorcraftservice.com/pu...20/S3OMAIN.HTM
Old Dec 5, 2008 | 03:45 PM
jmbaker3's Avatar
jmbaker3
Thanks, but its not the "cover"... This item is like a sleeve around the battery.
Old Dec 5, 2008 | 08:52 PM
ReAX's Avatar
ReAX
It is considered a heat shield or wrap, but I've never been able to get one from a dealer.
Old Dec 5, 2008 | 09:33 PM
SFeintuch's Avatar
SFeintuch
I bought a couple on ebay a while ago. Try Battery blanket , cover , or heat shield in your search.
Old Dec 5, 2008 | 09:59 PM
jmbaker3's Avatar
jmbaker3
Thanks... mine is pretty beat up, decaying... is it needed???... just looks like fiberglass insulation coming out of it.
Old Dec 5, 2008 | 11:41 PM
ReAX's Avatar
ReAX
Maybe in very cold areas. Not so much in warmer places. I wouldn't bother with it unless you find being without it causes a problem.
Old Dec 6, 2008 | 07:01 AM
jmbaker3's Avatar
jmbaker3
I read somewhere that this may be more for keeping the heat from the engine away, than cold from the weather. ????
Old Dec 6, 2008 | 08:59 AM
ReAX's Avatar
ReAX
I understood it as in really cold places, the battery will self discharge and the heatshield will hold in a little bit of heat so you have a better chance of starting it in the morning.
Old Dec 6, 2008 | 11:08 AM
FordxFour's Avatar
FordxFour
jmbaker3, You are correct,the battery wraps are for keeping engine heat out of the battery.
Summint racing has them, however they are pricey.
summitracing.com
timemachine455
Dec 15, 2016 04:42 PM
2002Fnord
1983 - 2012 Ranger & B-Series
Feb 25, 2016 10:58 AM
BarnieTrk
Jul 8, 2015 11:22 PM
Wild Weasel
Sep 27, 2011 12:37 PM
oem78
Dec 9, 2004 12:08 AM
