2 Trans. coolers?
Old Nov 30, 2008 | 12:39 PM
Old93junk's Avatar
Old93junk
2 Trans. coolers?
Replaced the stock "stacked plate" trans cooler w/ 16"x12" hayden cooler last year, I was told the are famous for plugging up and not great coolers. Question is: I now came possesion of almost identical cooler to the one I installed last year, can I run both?, or will this cause problems in cold weather or otherwise? Truck is 93 f350 460/e4od 2wd SC.
Old Nov 30, 2008 | 12:59 PM
85e150's Avatar
85e150
Two is overkill. It's not like you're in Death Valley. Does your fluid run through the aux. cooler, then to the one in the radiator, then back to the trans? If so, that should keep the oil at the right temp. Too hot is bad, too cold is no good either.
If you are not running back to the radiator, a thermostat valve/bypass set up might be wise.
You may also consider a filter in the line.
Old Nov 30, 2008 | 01:10 PM
Old93junk's Avatar
Old93junk
Yes its also running thru the rad. cooler as well. stock except for changing from stock aux. cooler to the hayden cooler. I suspected it might be overkill, guess I will put it on the ranger!.............thanks for the info!
Old Nov 30, 2008 | 04:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's backwards. The flow always should be from the trans to the radiator cooler then to the aux cooler, then back to the trans. The cooler in the radiator NEVER heats the ATF, it ALWAYS cools it.
Old Nov 30, 2008 | 04:55 PM
85e150's Avatar
85e150
My theory here is IF the aux trans cooler is overdoing it on a cold day, going back the radiator based cooler will bring the temp into the proper range.
How could it not do otherwise? It is using engine-temp coolant to cool the trans fluid. If the trans fluid is colder than the engine coolant, it would heat it up, wouldn't it?
Am I missing something?
Thanks.
Old Nov 30, 2008 | 08:19 PM
bashby's Avatar
bashby
Will the coolant temp will ever rise faster than the atf temp?THAT is the question.Not sure but I think the trans will make enough heat on its own, without pulling any from the motor. Aux trans cooler instructions say to rad first then aux cooler, IIRC
Old Nov 30, 2008 | 09:57 PM
EPNCSU2006's Avatar
EPNCSU2006
I remember reading this somewhere before too but I can't remember where.
Old Nov 30, 2008 | 11:00 PM
stuart1's Avatar
stuart1
Right
So correct Mark.
That is a common misconception that the fluid must be reheated.
Old Nov 30, 2008 | 11:03 PM
Old93junk's Avatar
Old93junk
Thats right, aux cooler the " extra" and last item in the fluid path back to the trans.
Old Dec 1, 2008 | 07:33 AM
Mark Kovalsky
Thanks.
Yes, you're missing something important.
The transmission cooler is in the cold side of the radiator. That's the side where the radiator has already cooled the engine coolant. When the truck is working hard on a hot day this side of the radiator is only about 15-20F colder than the engine temperature. But when the engine is working hard, so is the trans, so it was hotter than the engine! On a cold day, especially if the truck is empty, the cold side of the radiator stays within a few degrees of ambient air temperature. So if it's -10F outside, this side of the radiator may only be around 0F. And that's after the engine is fully warmed up!
None of this is specualation on my part. I've run tests from +115F to -40F ambient temperatures. I had 40-50 thermocouples on the trucks/cars I tested to be able to know the temperatures at many places. I could never find ANY condition where the radiator warmed the ATF. It just doesn't happen.
Old Dec 1, 2008 | 05:58 PM
85e150's Avatar
85e150
Thanks, now I gets it.
CPaulsen
16
Dec 5, 2014 08:52 AM
mototrig
15
Jan 17, 2014 06:20 PM
grec-o-face
Jul 14, 2012 01:42 PM
monstergarage87
Jan 29, 2012 05:16 PM
BigWhite94
56
Jul 21, 2010 08:56 PM
