Smoke problem its weird though
Old Nov 29, 2008 | 04:57 PM
fordtuff125's Avatar
fordtuff125
This happened last night with my 1996 f350 Powerstroke I was towing a pretty heavy load and lost all power and it started blowing tons of blue smoke I had to poll off the road. Well I tried starting again and nothing but blue smoke and it would not rev over 2000 rpm it would take me like 2 miles to just get up to 50 and no check engine light.
Well I made it to my exit only able to do 50mph and when I was decelerating (down shifting) I got a check engine light and then all the power came back and no more smoke.
Well today It will do the same thing No power, lots of smoke, and will not go over 2000 rpm in till I decelerate and get the check engine light. then it runs like normal with no smoke.
I can use a scanner on Monday to get the code but the last code I was getting was the ICP sensor and Turbo boost sensor high input code.
The truck is stock with 275k on it.
Old Nov 29, 2008 | 05:00 PM
c00nhunterjoe's Avatar
c00nhunterjoe
check to see if the ipr nut came loose
Old Nov 29, 2008 | 05:14 PM
fordtuff125
I'm kinda new to diesels ipr is the injecter presser regulator where is it located?
Old Nov 29, 2008 | 05:45 PM
c00nhunterjoe
when standing on the bumper looking striaght down on the motor it will be in the valley slightly towards the drivers side, has 2 wires coming out of it.
Old Nov 29, 2008 | 05:53 PM
otpracer100's Avatar
otpracer100
Possible idm on it's way out? Sounds similiar to my situation I had recently.
Old Nov 29, 2008 | 06:09 PM
fordtuff125
Ok I will check that thanks
Old Nov 30, 2008 | 11:29 AM
fordtuff125
The bolt is tight. But I am going to scan in rite now.
So I will check back in.
Old Dec 1, 2008 | 05:23 PM
fordtuff125
Ok just scanned it with a modis scanner hear are the codes.
P1298 IDM Fault
P1211 ICP Not Controllable - Pressure Abow/Below Desired
P0471 Exhaust Back Pressure Sensor Circuit Performance
P0476 Exhaust Pressure Control Valve Performance
Injecter pressure was 750psi at idle and 815 at 2000 rpm if that helps.
Old Dec 1, 2008 | 06:06 PM
Action4478's Avatar
Action4478
From the manual:....
  • DTC P1211 indicates that injection control pressure was above or below commanded desired pressure during self test mode.
  • Possible causes:
    • incorrect oil or viscosity
    • poor oil quality
    • gel fuel/no fuel
    • low fuel pressure
    • damaged IPR valve
    • high-pressure oil system leak
    • damaged high-pressure oil pump
    • damaged PCM
  • Verify correct oil quality/viscosity and correct fuel grade are being used for the temperature conditions.
I'll add low on oil.....
Old Dec 1, 2008 | 10:08 PM
fordtuff125
Oil is getting old I change mine every 6500 miles its at 6000 now.
Could it be the IDM going?
dmonell
Oct 11, 2013 06:04 PM
dmonell
Oct 10, 2013 11:42 AM
chris1911
13
Sep 17, 2013 10:42 AM
Sweetrocks
Mar 16, 2012 02:47 AM
DJdemon6696
19
Nov 22, 2007 06:52 PM
