Smoke on deceleration
Old Sep 13, 2013 | 12:23 PM
chris1911's Avatar
chris1911
I started getting smoke on deceleration yesterday, and I'm also getting some popping sounds at the same time, kind of like a small backfire but out of the carb. I'm colorblind but I think the smoke is light blue.
I'm guessing since it's happening and deceleration that it's the valve seals sucking oil. Does that sound right? I know the rings are pretty shot too because I'm getting blowby as well but that should cause smoke on acceleration, not deceleration?
How hard is it to change the valve seals without taking off the heads? Any help would be appreciated. I had no idea what I was getting into when I bought this thing! I sure am learning a lot though...
It's a 72 F250 Camper Special with a 390 BTW.
-Chris
Old Sep 13, 2013 | 12:32 PM
HIO Silver's Avatar
HIO Silver
I'd say your instincts are spot on.
To the best of your knowledge, how many miles on the ol' girl?
Old Sep 13, 2013 | 12:38 PM
chris1911's Avatar
chris1911
Well assuming the odometer is correct, 78,xxx. She's not in too bad of shape but not the best either. A little bit of surface rust here and there but nothing that a little TLC wont fix. The interior is pretty awesome but she's needed some work for sure. I redid the steering linkage and all of the bushings, suspension, and rebuilt the Holley 4160.
There's some weird stuff going on though too, it will only run if the points are really tight and the timing marks indicate it's at about 50*
It dies before you can even get it down to 20*. I think it may have jumped a tooth on the timing gear. I just need to baby and keep her running until December when I can do my rebuild.
Old Sep 13, 2013 | 01:08 PM
Area351's Avatar
Area351
Smoke on deceleration is usually worn rings.
Smoke on start up is usually worn valve guides and seals.
Old Sep 13, 2013 | 01:17 PM
chris1911's Avatar
chris1911
Are you sure about that? I'm pretty sure that smoke on acceleration is worn rings and smoke on deceleration is valve seals. My reasoning is that it doesn't smoke until you completely let off the gas, the throttle plates close and the engine vacuum is higher, thus sucking oil past the seals into the combustion chamber but I could be wrong.
Old Sep 13, 2013 | 08:06 PM
1972RedNeck's Avatar
1972RedNeck
It would also suck oil past the rings. I wouldn't think much oil could get sucked in when there is pressure keeping it out.
Old Sep 14, 2013 | 09:58 PM
Alex from GA's Avatar
Alex from GA
Yes you can replace the seals with the heads on. Remove the rocker shafts, either put a piece of rope in the cylinders or use an air fitting to hold the valves from falling into the cylinders, remove the keepers and springs and replace the seals. You need a special tool to compress the springs.
Old Sep 15, 2013 | 01:20 AM
BigBlockF350's Avatar
BigBlockF350
Probably your rings causing the smoking. You can do the valve seals without removing the heads, but I wouldn't bother since that's likely not your main cause and you say you're planning a rebuild coming up in December.
Old Sep 15, 2013 | 05:17 AM
2FordTrucks's Avatar
2FordTrucks
I had that problem on a old Camaro I had. Turned out that the intake was warped on the new crate motor. New intake and gasket and I was good. Of course it only smoked when I let off at around 65-70 mph.
Old Sep 15, 2013 | 08:10 AM
Area351's Avatar
Area351
Do a compression test. What are the numbers?
Old Sep 15, 2013 | 02:52 PM
1972RedNeck
There's the best suggestion so far.
Old Sep 16, 2013 | 07:17 PM
JEFFFAFA's Avatar
JEFFFAFA
2x Area on the compression test. Do it both wet and dry. Dry is as normal. "Then" Wet is you put a few healthy squirts of engine oil in the spark plug hole. There-by temporarilly sealing the rings. If the test numbers DON'T jump doing it wet the problem is in the heads.
Old Sep 16, 2013 | 08:56 PM
BigBlockF350
Originally Posted by JEFFFAFA
2x Area on the compression test. Do it both wet and dry. Dry is as normal. "Then" Wet is you put a few healthy squirts of engine oil in the spark plug hole. There-by temporarilly sealing the rings. If the test numbers jump doing it wet the problem is in the heads.
I think you meant to say that a jump in pressure with the wet test should point to bad rings not heads.
Old Sep 17, 2013 | 10:42 AM
JEFFFAFA's Avatar
JEFFFAFA
You are correct sir. I realized my mistake on the drive home yesterday.
.All please note. I edited my Post above to reflect what info I meant.
tndiesel
Aug 17, 2008 10:22 PM
Joe Finn
1997 - 2003 F150
Apr 21, 2008 11:23 AM
ErrorS
24
Jul 6, 2007 08:06 PM
relicpelican
1997 - 2003 F150
Sep 2, 2006 10:57 AM
Lizard94
Feb 2, 2003 09:31 AM
