Smoke problem its weird though
This happened last night with my 1996 f350 Powerstroke I was towing a pretty heavy load and lost all power and it started blowing tons of blue smoke I had to poll off the road. Well I tried starting again and nothing but blue smoke and it would not rev over 2000 rpm it would take me like 2 miles to just get up to 50 and no check engine light.
Well I made it to my exit only able to do 50mph and when I was decelerating (down shifting) I got a check engine light and then all the power came back and no more smoke. Well today It will do the same thing No power, lots of smoke, and will not go over 2000 rpm in till I decelerate and get the check engine light. then it runs like normal with no smoke:confused:. I can use a scanner on Monday to get the code but the last code I was getting was the ICP sensor and Turbo boost sensor high input code. The truck is stock with 275k on it. |
check to see if the ipr nut came loose
I'm kinda new to diesels ipr is the injecter presser regulator where is it located?
when standing on the bumper looking striaght down on the motor it will be in the valley slightly towards the drivers side, has 2 wires coming out of it.
http://inlinethumb46.webshots.com/23...600x600Q85.jpg http://inlinethumb22.webshots.com/27...600x600Q85.jpg |
Possible idm on it's way out? Sounds similiar to my situation I had recently.
Ok I will check that thanks
The bolt is tight. But I am going to scan in rite now.
So I will check back in. |
Ok just scanned it with a modis scanner hear are the codes.
P1298 IDM Fault P1211 ICP Not Controllable - Pressure Abow/Below Desired P0471 Exhaust Back Pressure Sensor Circuit Performance P0476 Exhaust Pressure Control Valve Performance Injecter pressure was 750psi at idle and 815 at 2000 rpm if that helps. |
From the manual:....
Oil is getting old I change mine every 6500 miles its at 6000 now.
Could it be the IDM going? |
