ok i installed my dp tuner f5 chip and now i can't start the truck i unplugged the chip and still no start on truck the pcm is plugged in and all fuses are good. i checked the hpop and it's full. anyone got any ideas on what could be the problem
Is the tach moving while cranking? How many RPM?
Do you see any smoke out of the tail pipe while cranking?
Fuel pressure should be 35psi minimum while cranking
Check all the fuses, especially #22 fuse under the hood again.
now the truck won't turn over at all i had the batterys checked and they are both good the truck was cranking but then it just got weaker and weaker and stopped
i think my starter is toasted i was getting a little scared because i put stage II's in it yesterday and thought maybe i messed up and it got hydro locked but i can turn it over by hand so i think the starter is just worn out
i'd take any kinda starter right now i'm so excited on whats it's gonna be like after the chip and stage II's i swear this is worse than being a little kid at christmas i need my power stroke fix
ok got the new starter in and now the truck cranks over great but still no start there is no rpm movement while cranking maxi fuse 22 is fine and #18 is blown. no smoke while cranking. i'm going to the store now to get the fuse anything else it could be?
