Hellwig anti-sway bar
Old Dec 4, 2008 | 10:32 PM
kappysworld's Avatar
kappysworld
Ok so I braved the freezing cold 57* ventura county night and resnapped some photos Some are sideways sorry.. to tired to fix em
Old Dec 5, 2008 | 12:33 AM
78Southwind's Avatar
78Southwind
That helps thanks for the pictures. It looks like I need to swap the block and the jounce block out and add a 2" spacer for the air bags to work.
Old Dec 8, 2008 | 03:10 PM
78Southwind
The Tech at Hellwig got back to me he said the sway bar will probably be OK on the pavement as I have installed it but could snap the end links if I really work the suspension. I think I will keep an eye on it and if I decide to do some hard off roading then I will order the long end-links.
I am also going to check with the Tech at AIR LIFT about their air bags.
Old Dec 8, 2008 | 06:05 PM
78Southwind
I checked with the Tech at AIR LIFT and their air bags will work easier with my set-up since I have a lift. Their air bags install between the Jounce and Bump Stop. For those that are interested in them I found them at www.suspensionconnection.com for $233.95 and www.summitracing.com matched the price and gave me $20 in summitracing bucks.
Old Dec 10, 2008 | 04:48 PM
Beechkid's Avatar
Beechkid
If the end of the bar is not parrallel to the ground you have the potential of restricting movement by creating a "bind". The result will be unequal performance stability (left compared to right) and the result either bending the sway bar or bending/breaking the end links.
Old Nov 22, 2010 | 11:20 AM
VR6Nutt's Avatar
VR6Nutt
Sorry to resurrect this old thread, but I seem to have experienced what Beechkid describes above. I just noticed that the right side end link was no longer attached to the sway bar...I thought my wife or I must of hit something...but what? Well in reading above that makes more sense. I could of sworn I measured the distance on both links when I installed them. Oh well - now I need to get a new link (if one is available) and replace prior to leaving on a trip, towing my trailer. And it needs to happen in the next 2-3 days...any suggestions? This is gonna be fun! Not.
Old Nov 23, 2010 | 03:08 PM
Beechkid's Avatar
Beechkid
You can fab one yourself using threaded rod, bushings a couple of nuts/washers. But the local auto parts store should be able to find one that will bolt right in- but you also need to find a staff member that has an iq above an ice cude too!
Hellwig should also be able to fedex one to you next day air
Old Nov 23, 2010 | 03:17 PM
VR6Nutt's Avatar
VR6Nutt
You know I was thinking about doing the same kind of engineering - but I called Hellwig yesterday and they were able to warranty it out. Since we are both on the left coast, I should have the new link by tomorrow! Thanks!
DarylJ
Aerostar
Mar 30, 2017 05:53 PM
MK_snipe
Apr 5, 2016 04:40 PM
Watcher58
Dec 1, 2015 01:14 AM
Watcher58
Aug 19, 2015 01:00 AM
V10_X
Jun 6, 2005 07:44 PM
