need help with a pinging problem
Old Nov 30, 2008 | 09:46 PM
95F350XL's Avatar
95F350XL
Easy way to ck the egr, is to get a vacuum pump and pull the hose off the top and apply vacuum. If it stalls it out its working fine. But EGR is the most common thing on Fords.
Old Dec 1, 2008 | 02:19 AM
Opossum's Avatar
Opossum
mrhorsepower67, All good stuff from the other guys on the EGR. One thing to add when you take out those plugs it souds like you know to pay attention to a color on the porcelain, but in your case you need to also take a look at the negative electrode, look for it being blued/discolored from excessive heat, if that thing is discolored it may be a hot spot and a source of the ping. The negative electrode being discolored is also a very strong indicator of an exsesive lean condition, witch is what a bad EGR many times will cause.
Old Dec 1, 2008 | 08:07 PM
mrhorsepower67's Avatar
mrhorsepower67
egr...pinging
I got the same jinx as all you....but that Egr valve position sensor, or EVP, EVR, or EGRC, has nothing too do with it?........Ill put an an EGR in all day long but they said make sure you check them first?............I dont know.....I am just gonna try the EGR itself. Thanks a lot guys....yous are always the best.
Old Dec 1, 2008 | 08:19 PM
Opossum's Avatar
Opossum
Let us know what happens I'm very curious what solves it.
Old Jan 6, 2009 | 07:29 AM
SuperFord's Avatar
SuperFord
Any update on this? My 97 is also pinging and I am trying to cure it. Just curious how you made out. Thanks
Old Jan 6, 2009 | 12:22 PM
i1dery's Avatar
i1dery
Just a thought.
I was told that if you have a TFI (Thick Film Ignition I beleive) you should not attemp to adjust the timing as you my damage the componants, The timing is all done electronically by your computer with all the inputs from variouse sensors and stuff. Try going to
FORDFUELINJECTION.COM and reading about what I was saying it my give you some insite on your pinging problem.
Old Jan 6, 2009 | 05:09 PM
EPNCSU2006's Avatar
EPNCSU2006
The base timing still has to be set on TFI systems (all EFI trucks in the year range of this forum). The computer advances blindly from the base timing, so if the base advance is incorrect, timing advance will never be correct at any operating condition.
Old Jan 6, 2009 | 06:13 PM
Jeff Dodson's Avatar
Jeff Dodson
The cure for mine, I had to change the tube that goes from the manifold to the EGR. Mine was cracked and kinked, so it wasnt flowing enough. I replaced that from FORD $91.00
Old Jan 7, 2009 | 07:48 PM
daninline's Avatar
daninline
Ok I working on the same issue right now. I don't have any vacuum at the EGR valve and no power at the EGR Vacuum Solenoid.
So I was thinking if the EGR valve is stuck open then I would not get any power at the EGR Vacuum Solenoid... right?
if I unplug the EGR postion Sensor will that power up the vacuum solenoid.
Thanks
Dan
Old Jan 7, 2009 | 09:11 PM
EPNCSU2006's Avatar
EPNCSU2006
There should be 12V at the EVR solenoid with the key turned on. The computer pulse width modulates the ground side of the EVR to vary EGR opening. I don't think the EVP sensor has any control over the computer activating the EVR.
Old Jan 8, 2009 | 09:08 AM
daninline's Avatar
daninline
Thanks so my next question then would be where is the fuse. I tested a bunch of them but there could be one missing from the former owner who hacked all kinds of stuff
Old Jan 8, 2009 | 04:26 PM
EPNCSU2006's Avatar
EPNCSU2006
The circuit that powers the EVR also powers the fuel injectors, the TAD and TAB solenoids, the coil, and the engine computer. That comes from the EEC relay, which on my 87 is fed by a fusible link. I'm thinking newer trucks used fuses, but I don't know.
Old Jan 21, 2009 | 08:57 AM
  #28
95X15's Avatar
95X15
In 95 the subject power comes from fuse #1 in engine compartment fuse box thru the PCM power relay to a splice, then to EVR,IAC, AIRB sol fuel injectors and Evap canister purge solenoid. Just remember they had 2 years to change this.
Old Jan 25, 2009 | 06:06 PM
  #29
Skinsfan6's Avatar
Skinsfan6
Why would you increase the timing to 12 degrees btdc? That will make it more likely to detonate (ping). Set it back to 10 degrees and see if it still pings. If so, you want to retard the ignition timing. You'll want to go down to 8 degrees or something similar.
bren_tx
May 28, 2010 08:41 AM
ham-n-swiss
Jun 3, 2009 03:59 PM
t4kne
May 18, 2007 09:14 AM
jgirard
3.0L V6
Jun 19, 2004 08:45 AM
catbird7
Aug 29, 2003 04:46 PM
