I have a 78 F250 with the 4 speed (granny Low) tranny. Yesterday I got off the interstate pulling a trailer and when i went to down shift i could move the shifter but the tranny stayed in 4th gear. It seems something sheared off inside. I've never dug into one of these before so I'm not real sure what it could be. I limped the truck to one of the fire stations (that is my profession) where i could leave it until i get another truck and trailer to tow it home. This truck is my baby, it has been in my family since new and only has 48,000 original miles on it. I would like to fix it myself. I don't let to many people work on her. if anyone has some ideas or helpful info i would apprieciate it.
Which 4 speed do you have? First off, I would pull the shifter out, see if the innards are in order. A t18 you have to unscrew the shifter retainer, the NP435 you will have to push down, 1/4 turn, and will pop out. Take a looksie down the hole, you will see your shift rails. The shift rail for 3/4 is on the right hand side. Take a large screwdriver, align all the shift rails up so they all center up in the middle. That will put you into neutral. Check the end of the shifter, make sure nothing has sheared off. If it has, a trip to the junkyard to find another is in order.
Thank you for the reply. I guess I assumed I had the T18. This is a 2 wheel drive stock F250 custom. I have my tow rig all set up so i will be taking my truck home in the morning after I get off shift.
For '78 your 4 speed should be either a NP435, non-synchro first, R is to the right and down, or the T19, synchro first, R is to the right and up. It is also possible you have a T 18, non-synchro first, either up or down for R due to use of two different shifter assemblys.
T 18 will have 13-01 cast into them, T 19 will have 13-09.
Anyway, removal of the shifter and cover may tell your tale here. For the NP 435, it's push down on the stick and turn. The others have a cover held on by screws.
Seems like the shift forks wear, or some little nylon part falls off, etc.
This here is the site, they have a schematic link for the T18 and a rebuild guide for the NP435. These should have pics etc for the parts you may need.
Good luck.
Removed by FTE staff, every time it is placed in a spot it will be removed do not link to that site.
"..cover held on by screws." That would be the top cover, not really the shifter. It appears the stick comes out by unscrewing the cap at the bottom of the stick. Not sure what you can do in this situation by just pulling the stick? But, if it's broken as you suggest, I guess that would tell the tale.
Who is Slick 60? [edit] nevermind, 30 seconds on google found my answer. So why is this guy different than anyone else?
I have inspected a few NP435s for resale, some still had those nylon bushings on the shift forks, some were worn off. Both did not seem to have any unusual issues with shifting. I still suspect that the end of the shifter has broken off. If the gears had something jammed in them, the truck would not move, nor would he be able to move the shifter. If a shift fork was broken, it would be possible to shift into two gears simultaneously, that would instantly lock the transmission up, and stall the engine every time you let the clutch out. With the shifter, do you feel any remnants of a shift gate(H pattern), or does it free float?
