injector choices.
Old Nov 26, 2008 | 03:53 AM
rockitdog's Avatar
rockitdog
injector choices.
Well, correct me if I am wrong. Looking at the engine on my truck, It looks like a federal emissions engine, Valve cover label is black and says " meets all US federal emissions " All the fuel pump has on top is 2 lines headed back towards the front of the engine, no starship enterprise. The build date is 09/1997
So the question is, what injectors does my engine have, I am guessing single shot AA's? What is a good upgrade? I like the rosewood stage 1 DIY. Should I stay with single shot, Will the split shot injectors even work with my engine config?
What tunes are best for stage 1's ?
I am just looking at my options. Thanks in advance
Old Nov 26, 2008 | 06:45 AM
tjbeggs's Avatar
tjbeggs
Yes you should have AA's. Stay with single shots and get some stage 1's with tunes from TDP or DP Tuner!. Splits will work and do well but in the end unless you are GIVEN a working set of AD's its not worth it.
Old Nov 26, 2008 | 09:16 PM
rockitdog's Avatar
rockitdog
Thanks for the info. The AA's seem to be less expensive anyway. Just out of curosity, what turbo config are you running?
Old Nov 27, 2008 | 07:18 AM
arkredneck's Avatar
arkredneck
i just odered some stage II's and a chip from dp tuner ill let you know how it all works i should get them this friday or saturday if the mail service delievers after thanksgiving
Old Nov 27, 2008 | 08:23 AM
rockitdog's Avatar
rockitdog
Great, I look forward to hearing about it!
Old Nov 27, 2008 | 08:33 AM
tjbeggs's Avatar
tjbeggs
Stock turbo right now. I have a Holset H2E in the works right now.
DougJ_1997PSD
Apr 6, 2015 08:17 PM
fullsize4wd
Jun 10, 2013 04:45 PM
MikeSDK
May 16, 2012 09:44 AM
skimac10
Jul 28, 2008 08:20 AM
foxracing0934
22
Apr 30, 2008 10:21 PM
