Sponsored by: Real Truck
ford gears any good
Old Nov 24, 2008 | 10:54 PM
conman3300's Avatar
conman3300
ford gears any good
are ford gears any good and does it really matter what brand of gears i get j/w
thanks
Old Nov 25, 2008 | 12:46 AM
Monsta's Avatar
Monsta
Sit. Stay.
It's been said that Ford gears are the quietest gears. If noise is a factor then you should consider Ford gears. That's what I regeared with. Course it depends on what ratio you want to go with.
Old Nov 25, 2008 | 01:41 AM
cartmanea's Avatar
cartmanea
I've also read they're the quietest, I think they are more polished so they takes less break in time. Its hard to beat Ford gears on pricing though...well unless you want to pay less. I have a set of Yukon 4.30s waiting to go on at home, they were way cheaper than Ford and are good quality.
Another thing, I think Ford gears are actual 10.5" gears while all aftermarket are actually 10.25", but I could be wrong.
Old Nov 25, 2008 | 07:58 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
In general, they are more likely to "match up" to the existing pinion depth and ring backlash shims. The pinion depth is set with a gauge (dummy pinion), so Ford's pinions are all the same length/depth.
I'd imagine that aftermarket sets aren't as consistent, possibly needing some adjusting of shims after assembly and checking the gear contact pattern.
But who knows until you try it. If you're having them installed by a shop, get whatever they recommend, or whatever you like price-wise. MAKE SURE they do a gear contact pattern check. Might want to have them call you when they have it done and take pictures
Old Nov 25, 2008 | 08:26 AM
conman3300's Avatar
conman3300
ok thanks guys i think im going with ford then
you think 4:30 from them will be good and anyone have a guess on there price for rear and front,rear
Old Nov 25, 2008 | 10:39 AM
cartmanea's Avatar
cartmanea
Check Randy's Ring and Pinion, ringpinion.com
They seem to have good prices, I don't think they list Ford gears for the D60, I'm not sure if they even exist.
Old Nov 25, 2008 | 11:26 AM
Monsta's Avatar
Monsta
Sit. Stay.
Compare prices with the OEM supplier sponsors here as well.
Old Nov 25, 2008 | 11:33 AM
ReAX's Avatar
ReAX
I'd be willing to be that ford buys their gears from AAM just like chevy does. Years ago, we compared a set of motives (made by AAM) to a brand new set of chevy gears. The stamping on the pinions were identical, the only difference was the packing and box. Ford doesn't make every part they sell/use, AAM is a pretty big name in gears. They produce for several brand names, including Motive and Yukon.
Old Nov 25, 2008 | 12:19 PM
F250Wheels's Avatar
F250Wheels
I have regeared my trucks with after market gears from 4wheelparts with no problem.
I did just regear my F450 and had to go to dana to get the gears I wanted.
Old Nov 25, 2008 | 12:26 PM
Diesel Smoker's Avatar
Diesel Smoker
I would agree 100 % go buy from a sponsor or another gear specialty shop and save your self some money for the gear install.
Old Nov 25, 2008 | 12:39 PM
krewat's Avatar
krewat
From FTE/PARTS-GUY, the rear pinion is pretty cheap at around $238 if it's a SRW truck.
The front is around $450, and like someone said, they wouldn't be "Ford" anyway but Dana, which is probably why the big price difference, they are reselling someone else's gears.
Definitely check out our sponsors, and FTE/PARTS-GUY for OEM Ford stuff at a big discount.
mey
Large Truck
Aug 19, 2009 12:50 AM
bain_b
1983 - 2012 Ranger & B-Series
Jan 28, 2008 02:55 PM
GerRod
Oct 13, 2006 06:10 PM
Inwywind
Jul 8, 2004 06:58 AM
Ford Truck Racer
Sep 30, 2002 10:20 AM
