Rear Differential Gears
Old Jan 27, 2008 | 04:58 PM
bain_b's Avatar
bain_b
Question Rear Differential Gears
I was wondering if anyone had heard of switching out the rear differential gears. I have a 2004 ranger manual 2x4. I think that ford designed it to be able to tow jet-skis and things, but with the current ratios, i feel like 1st gear is a waste. any ideas? can i buy a new lower gear ratio set for the rear axle?
Old Jan 27, 2008 | 05:18 PM
RangerPilot's Avatar
RangerPilot
First things first, you need to figure out your current axle ratio.
You can either look at the tag on the rear differential, or use this:
https://www.ford-trucks.com/article/...r_Decoder.html
The way you describe it, sounds like you have 4.10s.
Lower (numerically higher) gear ratios are great around town, great acceleration, and can typically tow more.
Higher (numerically lower) gear ratios are better on the highway, where they produce lower RPMs and better mileage.
You can buy a gear set (ring and pinion) for less than a hundred bucks if you shop around, and a lot of people like to trade up to lower gear ratios, so you could find someone with 3.55s or whatever you want and trade, assuming you have 4.10s.
Common ratios for the 8.8" axle are 3.08, 3.23, 3.55, 3.73, 4.10, 4.56.
Old Jan 27, 2008 | 05:48 PM
bain_b's Avatar
bain_b
yeah, i just checked and you are right. i have the 4.10 LS. and do you know where i should go about looking for a new gear set? also, i only consider myself a mediocre mechanic, so is relatively easy to do? thanks!
Old Jan 27, 2008 | 06:07 PM
RangerPilot
The "easiest" thing to do would be to find someone with the same axle and just swap axles across.
What kind of ratio are you looking for? Do you do a lot of highway running? Or do you want to just drop the RPMs around town and stuff?
Old Jan 27, 2008 | 07:59 PM
bain_b's Avatar
bain_b
well, i don't know exactly what ratio i want, though i was thinking like 3.5-3.75
mainly, i want to be able to go 70 mph on the interstate, where i do a lot of driving, and not have the engine reving 2750 rpms... that being said, if this is the kind of thing that requires more trouble than it is worth, then i can live. i am not getting bad gas millage, around 21 mpg overall.
Old Jan 27, 2008 | 09:46 PM
rubydist's Avatar
rubydist
What size tires are you running? 4.10s are 'right' for around 30" and taller tires.
Old Jan 27, 2008 | 10:48 PM
RangerPilot
21 MPG may be super low or real good, depending on what engine you have.
If you have the four banger, 21 MPG is low, and that's about perfect RPMs on the highway.
The 4.0L SOHC I'd say it was pretty good, won't hurt it to rev.
The 3.0L, I'd definitly suggest higher gears.
If you're doing a lot of highway driving as you say, I'd say 3.55s would be good if you're running stock tires.
Old Jan 28, 2008 | 08:24 AM
sfcwoodret's Avatar
sfcwoodret
I've got the 4.10 and wouldn't trade those gears at all.
Old Jan 28, 2008 | 02:08 PM
4D TRUCKS's Avatar
4D TRUCKS
I currently have 3.73 in my 96 Ranger and wish they were 4.10. It runs alright, but not that good while driving up hills or when the a/c is on.
Old Jan 28, 2008 | 02:14 PM
RangerPilot
You guys need to make sure you spec what engine you have when talking about gear v. power available.
My Ranger with the 4.0L would pull hills with the A/C easy in OD with 3.08s...the engine makes a huge difference with different gears. 4-bangers with 4.10s can have problems pulling hills even.
Old Jan 28, 2008 | 02:55 PM
bain_b's Avatar
bain_b
I have the 3.0 liter. Power hasn't been a problem at all. I have enough low-end power right now to take of from a stop, without using the accelerator (on level ground).
I was afraid of the mpg issue. I thought that my numbers were a little low compared to how much highway driving I do. I will look in the 3.55 rear end; I may be able to make a switch at an auto-yard. Thanks a lot for all of the info RangerPilot!
juang316
Sep 1, 2013 04:34 PM
Big Red 78
Jan 22, 2010 04:59 PM
ra_dost
Apr 30, 2007 05:27 PM
bks90F150
Feb 20, 2006 12:11 PM
YoPaulie
1997 - 2003 F150
Jan 10, 2004 07:23 PM
