voltage regulator
Old Nov 23, 2008 | 03:08 PM
willcharl's Avatar
willcharl
voltage regulator
86 f-250 5.0:
my truck keeps killing the battery so i just took the alternator out and cleaned the brushes and what not. then took it to napa to get checked. they told me it was good. and the truck dies as soon as you disconnect the battery. so i was wondering if you guys think its the volage regulator?
Old Nov 23, 2008 | 04:58 PM
Franklin2's Avatar
Franklin2
While the engine is running, check the voltage on the "f" terminal of the regulator. If you have voltage on the "f" wire, then the regulator is working.
A lot of times people work with and around the alternator without disconnecting the battery. They will get against the output wire and blow the fusible link. To see if this is blown, with the engine off, check to see if you have battery voltage on the large output wire on back of the alternator.
Old Nov 26, 2008 | 07:42 PM
willcharl's Avatar
willcharl
my truck doesnt have a large wire fron the altenator. it has 2 plugs does this maen the voltage regulator is on the altenator? and if i were test the voltage from that wich wire would i test?
Old Nov 27, 2008 | 11:41 PM
Franklin2's Avatar
Franklin2
It sounds like the internally regulated type alternator. The output wire is the black/orange strip wire and you may have two of them side by side.
Old Nov 30, 2008 | 11:48 AM
willcharl's Avatar
willcharl
ok ill check that out and get back to you guys
Old Dec 1, 2008 | 10:55 AM
Kylet8020's Avatar
Kylet8020
<P>
While the engine is running, check the voltage on the "f" terminal of the regulator. If you have voltage on the "f" wire, then the regulator is working.</P>
<P>&nbsp;</P>
<P>A lot of times people work with and around the alternator without disconnecting the battery. They will get against the output wire and blow the fusible link. To see if this is blown, with the engine off, check to see if you have battery voltage on the large output wire on back of the alternator.
</P>
<P>&nbsp;franklin2 i did all this with my starting problem that i had thought it might be the regulator but i had good volts from all points u said to check<IMG border=0 alt=0 src="http://images.ford-trucks.com/forums/images/smilies2/mad0228.gif" smilieid="63">why cant this be easy...</P>
Old Dec 1, 2008 | 11:30 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I think that it may be the plug going into the alternator is shorted internally.
Pentagon to deploy 20,000 troops for domestic emergencies - Yahoo! News
Old Dec 1, 2008 | 11:36 AM
Kylet8020's Avatar
Kylet8020
what does that mean??? this is the post i started on it https://www.ford-trucks.com/forums/7...tart-help.html
if ya could help out anyway that would be great i have checked grounds & fuse links
srry willcharl for highjackin your post
Old Dec 1, 2008 | 01:53 PM
bashby's Avatar
bashby
If it has the long 3 wire (2 big wires, output, and one small, )plug in addition to the D shaped plug, there is a lot of problems with the plug going bad. They used to come with reman alternators. Should be available through local aftermarket parts store.
Old Dec 1, 2008 | 02:10 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Jeesh, I don't know where the link I posted above came from.
Sorry.
https://www.ford-trucks.com/forums/s...3&postcount=13
Old Dec 3, 2008 | 06:12 PM
willcharl's Avatar
willcharl
i pulled the wires off and checked the all the wires for continuity and i found one bad plug and replaced it and now its working great. it was under $13 to fix. thank you guys
Old Dec 3, 2008 | 07:06 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Glad to hear it was relatively painless.
Welcome to FTE, and don't be a stranger!
Old Dec 5, 2008 | 11:06 PM
Sport45's Avatar
Sport45
Originally Posted by willcharl
86 f-250 5.0:
Don't do that. Disconnecting the battery while the engine is running doesn't do nice things to the charging system or electronics.
Gla you found the problem and were able to fix it.
valley1221
Apr 25, 2013 09:21 PM
bigred66
Oct 1, 2012 07:21 PM
SkipTLoo
Oct 15, 2010 09:27 AM
51truck
Electrical Systems/Wiring
Nov 4, 2002 09:16 PM
pyr0maniac
Jun 1, 2002 06:19 PM
