Bronco II Ford Bronco II
front axle ?
Old Nov 21, 2008 | 10:20 AM
jleal_21's Avatar
jleal_21
front axle ?
what front axle come in the bronco 2s, and how well do the hold up on 33 in tires?
Old Nov 21, 2008 | 06:51 PM
rebocardo's Avatar
rebocardo
Dana 28 1984-1989 - max tire size should be 31s with a very light foot
Dana 35 1990 - max size should be 33s.
Old Nov 24, 2008 | 06:47 AM
tbolt 460's Avatar
tbolt 460
all depends how you run the skinny pedal too
Old Nov 24, 2008 | 01:24 PM
Help I M Stuck's Avatar
Help I M Stuck
yep..the skinny pedal is the key point. I"ve been running 35x12.50x15 BFG MT's on my dana 28 for years..and have been doing nothing but rock crawling off road and have never had a problem.
Toooo much skinny and yeah..POOF as with anything..
Old Nov 24, 2008 | 06:05 PM
danr1's Avatar
danr1
Yea I've found the lock out's housing itself tends to snap off before anything else does, even running stock sized wheels.
If/when it happens it's real easy to fix, pull the wheel off and whats left of the lockout housing, slide on a replacement lockout assembly and put the wheel back on!
Sure other parts can and will break, but all I've ever broke so far is the lockouts, end snaps clean off. Lucky? Could be.....
jleal_21
1983 - 2012 Ranger & B-Series
Nov 20, 2008 02:08 PM
pokerpuller
Dec 7, 2005 10:13 PM
tryppster
Mar 29, 2002 08:59 AM
4xfordman
Feb 9, 2002 11:24 PM
OLEBLUE
1997 - 2003 F150
Feb 6, 2000 11:53 AM
