solid front axle
Old Jan 27, 2002 | 04:54 PM
4xfordman's Avatar
4xfordman
solid front axle
I have a question regarding the front axle on a F250 from the years of 92-96. Are they all solid front axle?
Old Jan 27, 2002 | 06:01 PM
Truckslayer84's Avatar
Truckslayer84
solid front axle
Nope, It's going to be a IFS (Independent Front Suspension) front end. There is a article on the website to convert to a solid front end though, you might want to take a look.
Old Jan 27, 2002 | 08:09 PM
Pastmaster's Avatar
Pastmaster
solid front axle
The light duty F-250's had a Dana 44 and the HD's had a Dana 50. They were IFS like mentioned above.
'93 F-150 loaded and modified!
http://briefcase.yahoo.com/toydestroyer1
Old Jan 28, 2002 | 05:34 AM
rabidranger's Avatar
rabidranger
solid front axle
They were actually of the TTB kind of IFS (twin traction beam). A Dana 60 from a similar year F350 will bolt right in the TTB dana 50's place.
Old Feb 7, 2002 | 10:01 PM
fortythree's Avatar
fortythree
solid front axle
so, (i know i have IFS) if i have a 96 F250 HD, that means i have a TTB dana 50 front end? which means i can easily switch to a dana 60 solid front axle (from a 96 f350)? ...sure would save me a lot of money and hassle as far as lifting my truck goes!
BUT, what about the gears?... the gears in the dana 60 solid axle would have to be the same ratio as the gears in my rear end right?
thanks (man i learn alot from this board, i love you kind people!)
Old Feb 7, 2002 | 10:36 PM
Cope's Avatar
Cope
solid front axle
Yep, gears have to match.
-Cope
95 F-150 4x4
4.9L M5OD
Front Truetrac Rear Detroit
3.73 Precision Gears
Warn Premiums
4" Superlift Superunner
Old Feb 8, 2002 | 01:49 PM
Ryan50hrl's Avatar
Ryan50hrl
solid front axle
A word of caution, i've heard that the solid axle dana 60's will not swap directly into F-250's due to crossmember interference. Before you spend a ton on a dana 60 you may want to search about this. There should be other posts about it. Good luck
Ryan
Old Feb 8, 2002 | 03:01 PM
lanero's Avatar
lanero
solid front axle
Here is a link to the tech article explaining the swap:
https://www.ford-trucks.com/articles/buildup/dana60conv.html
Roger Lane
Old Feb 8, 2002 | 05:48 PM
brett_d's Avatar
brett_d
solid front axle
Old Feb 8, 2002 | 07:58 PM
fortythree's Avatar
fortythree
solid front axle
well, i'm stoked.. local auto wreckers has a dana 60 with 4.10 gears out of the front end of a f350 i think i'm gonna swap my front end... i still need more info from him as i am only assuming that the width of the axle will match the width of my rear axle... he also has a sterling axle with 4.10 gears for the rear that he says will match (i'm not sure if it is out of the same truck, i think so tho)... i'd rather just buy 4.10 gears for my rear and keep my rear axle tho... (just have to weigh the cost variables)
how can i tell which model of rear axle i have?... to the right of the dif it has the numbers "6065" punched in, can anyone tell me what that means? (i obviously can measure to find the width)...
thanks a bunch in advance.
Old Feb 9, 2002 | 03:33 AM
ddestruel's Avatar
ddestruel
solid front axle
[updated:LAST EDITED ON 09-Feb-02 AT 04:37 AM (EST)]It will bolt right in, my springs had 2" of lift in the front so there was no conflict with the cross member, front driveline should be shortened 1" though. Actually any dana 60 for an 80to 97 truck will fit the 93 and earlier are prefered for the King pin designs especially for cross over conversions. The King pin design will wear out less often than the later ball joint style. If you are near the North West there is a guy in canada that will beat the shorts off of any wrecker in the states. I got one for a friend three weeks ago, hub to hub with tie rods and sway bar for $800. Email me ill give you his number. As to your rear you have a Sterling 10.25 rear axle. What gears do you have right now? 3.55? what size tires are you running?
Good Luck
Dusty
F-250 now 350 4x4 ext cab SBed Green Monster (Used to have)205000 miles, Mass air 460 w/ performance heads, E40d to 5spd conversion, 205 T-case, 4.11 gears (looking for 3.55's), Power-Lok equipt dana 60 front, Doug Thorleys and swapped in EFI 33 gallon bronco rear tank. 33's on 16x8" Outlaw II's, Truck is soon to be a 300HP 715lb/ft flywheel rated 5.9L cummins diesel w/ NV4500 5spd and NP205.
My other toy is a '69 CJ-5 354 Hemi 4 spd 4.88's 32x12.50 MThompsons w/ power-lok 44 rear
Old Feb 9, 2002 | 04:39 PM
fortythree's Avatar
fortythree
solid front axle
well, i'm in BC Canada
currently i have 285/75R16 BFG all terrains (approx 33" tires) (actually 32.83 after doing the math!)..
i want to go to 35's within the next few months so i figure if i buy a dana 60 front end with 4.10 gears, and buy 4.10 gears for my rear i will be good.
thanks a lot for the help.
YGM
Old Feb 9, 2002 | 11:24 PM
ddestruel's Avatar
ddestruel
solid front axle
Hey id be willing to send you the 4.10's as soon as i track down some 3.55's for my Sterling Rear. Ill email you that info on that guy. Good choice for the Dana 60.
Dusty
Walwal44
Sep 13, 2014 10:18 AM
brokeisnojoke
Jun 21, 2011 09:27 AM
slickerthanyou
Feb 25, 2011 06:54 PM
gonecrazyi
26
Jul 27, 2007 09:39 PM
4xfordman
Offroad & 4x4
Mar 17, 2002 07:54 AM
