Bronco II Ford Bronco II
Starting Issues..... Grinding
Old Nov 21, 2008 | 08:06 PM
99whiteford's Avatar
99whiteford
Hate to bring bad news ,,but you have the wrong flywheel..I own a starter and alternator rebuild shop and have been down this road several times.If possible the best cure would be to get a starter,and flywheel from another truck.
Old Nov 21, 2008 | 10:14 PM
Ship Boy's Avatar
Ship Boy
Temporarily Deactivated
I believe I know why he sold it. You got burned my man.
Old Nov 22, 2008 | 11:54 AM
gatlin04's Avatar
gatlin04
Im going to the junk yard here soon to get it.... if anyone disagrees, tell me now!
Old Nov 22, 2008 | 02:30 PM
97Centurion's Avatar
97Centurion
Rub my Belly
Before you start pulling stuff apart. Count the teeth on the fly wheel in the truck and the one you got from the junk yard. If you pull stuff apart. check and make sure that you have the proper spacer if you do pull stuff apart.
Wish I had more time on my hands Warrensburg is only about an hour and a half from here.
Old Nov 22, 2008 | 06:23 PM
gatlin04's Avatar
gatlin04
i went to Pick and Pull today and i got a flywheel but no starter. There wasnt a starter on it. The transmission was already dropped, so it was only a few bolts to get it off...
I was in a hurry and all i got was the flywheel.... was there a spacer that i was supposed to get also? I hope not or i hope that Oreillys has one....
I got an interchangeable list from the front desk and it said that a flywheel from a 91 Automatic Explorer..... i hope that they were right! lol... I will get out there early tomorrow morning and start doing some work..... wish me luck!
Old Nov 23, 2008 | 06:32 PM
rebocardo's Avatar
rebocardo
Not on my manual transmission.
flywheel = manual transmission
flex plate = automatic transmission
flywheel = solid piece of metal
flex plate = thin gauge steel with spaces with a ring in the middle
Do you have an automatic or standard transmission?
You can't have a "flywheel" with an "automatic", it is a flex plate. Maybe this is why nothing is lining up.
Old Nov 23, 2008 | 06:38 PM
gatlin04's Avatar
gatlin04
its a flex plate.... i have an automatic....
hotrodharley84
May 21, 2013 12:17 PM
Hybris
1997 - 2003 F150
Sep 25, 2009 11:14 PM
jimpennycuff
Jun 15, 2007 10:49 AM
kshusker00
New Member Introductions
Nov 12, 2006 06:26 PM
mojoe212000
Dec 14, 2005 11:31 PM
