Sound Upgrade
Old Dec 13, 2009 | 07:20 PM
  #31
HD74's Avatar
HD74
One of the things accomplished today was applying the 1/2 inch dynaliner to the firewall and installing the ABS firewall cover, throttle arm, running the speedo and clutch cable.
The next step is to drill new holes in the firewall for the newly refurbished heater.[/IMG]
Old Dec 14, 2009 | 07:20 AM
  #32
tip49's Avatar
tip49
Firewall holes
HD;
I installed foil sided heat liner first on my firewall , then used 1/8" PVC over it. I tried drilling the heat liner but it is like fibre wool and just balled up. I ended up heating awl, pipe, tubing for whatever size of hole I required and "burned through".
I haven't installed Dynamat yet, but plan on doing doors, roof, rear of cab.
Nice job on yours; I built my firewall linier and it was a challenge to install alone.
Tom
Old Dec 14, 2009 | 09:08 AM
  #33
HD74's Avatar
HD74
Originally Posted by tip49
HD;
Tom
Thanks Tom, I removed the fiber and replaced it with dynaliner, I would also consider after laying down the dynamat to follow it up with the liner because its and excellent thermo barrier. Once the tranny cover is buttoned up I will be laying down 1/4 inch layer of dynaliner over all the dynamat in the picture above.
If you think the firewall was tuff wait till you get to the headliner.
Old Dec 14, 2009 | 12:09 PM
  #34
Stephen67's Avatar
Stephen67
I used something similar in my '67 Mustang, makes a HUGE difference. Not only is there a significant decrease in road noise, there is a very very significant increase in the sound system.
Great job ^_^
Old May 12, 2010 | 05:04 PM
  #35
HD74's Avatar
HD74
A little update on the interior/dash. Finally have all the electronics working, I mean switches, lights, turn indicators, horns, wipers, heater and the radio. I can even play my Ipod thru it.
If we get some decent weather this weekend the headliner is next.
Old May 12, 2010 | 06:24 PM
  #36
dennisb56's Avatar
dennisb56
checked out your pictures, it really looks nice.
Old May 13, 2010 | 01:07 AM
  #37
HD74's Avatar
HD74
Thanks Dennis, I checked out your too.
Björn
Nov 18, 2014 03:19 PM
RedBoat
6.7L Power Stroke Diesel
17
Jun 26, 2012 09:52 PM
SuperDuty93
Jun 25, 2012 10:56 AM
fifty-two_f1
26
Feb 4, 2012 11:21 PM
Dutch123
1978 - 1996 Big Bronco
26
Jul 21, 2010 07:48 AM
