Sponsored by: Real Truck
towin
Old Nov 14, 2008 | 06:49 PM
liltow's Avatar
liltow
towin
need help with this 1990 rollback with boom . just replaced the 351 winsor with the same . every thing went well except for a small anti-freeze leek comin from the back of the motor . Also put new cluch assembly in, and cluch master . And cluch still low . ( internal slave)Now my front end ,had mad work put into it . upper/lower ball joints ,lower arm bushing front shocks ,axle pivot bushings , and alignment . So now , my qusetion is , why do I keep hering a knock coming from the passenger side front wheel well . Only when I hit bump . Thanks just wanting to keep this truck in good shape . the last owner didn`t .
Old Nov 14, 2008 | 07:15 PM
hughjazz's Avatar
hughjazz
body mounts?
my 91' f350 made a wicked noise in the same area in bumpy stuff
Old Nov 14, 2008 | 09:07 PM
nitrogen's Avatar
nitrogen
check and retighten the upper and lower shock mounts, if even slightly less than totally tight they can make some incredible noise. i saw a new dodge a few years back it sounded like major stuff was breaking and all it was was a slightly loose shock
Old Nov 15, 2008 | 01:25 PM
liltow's Avatar
liltow
thanks team , I`am on it . how about that hydralic cluch . having a hard time bleeding it
Old Nov 15, 2008 | 03:11 PM
hughjazz's Avatar
hughjazz
Look under the dash at the clutch rod. I bet you have a really warbled out end causing the clutch problem. when looking underneath. move the pedal up and down. (the freeplay) you will probably see the looseness.
https://www.ford-trucks.com/article/...eshooting.html
madman1966
20
Oct 11, 2013 06:30 PM
redeagle72
1983 - 2012 Ranger & B-Series
Nov 18, 2011 08:36 PM
1bigjoe
Jul 23, 2011 04:05 PM
pintoches
Jun 1, 2008 06:33 PM
odie780
Mar 2, 2004 07:15 PM
