Packing bearings
Old Nov 13, 2008 | 02:11 PM
JasonI's Avatar
JasonI
Packing bearings
Is there a site or link somewhere for a quick tutorial and removing and repacking wheel bearings? I have an '89 F250 2wd with 60k(not a typo) miles and I can hear a rotating type squeal. Regardless it needs done by now I'm sure. I'm a fair shade tree mechanic and even know how to use most of the tools I have, I've just never had a vehicle with serviceable bearings. Any help would be greatly appreciated.
Old Nov 13, 2008 | 04:11 PM
jroehl's Avatar
jroehl
Get a bearing packer. It just threads apart, you place the bearing in it, thread it back together, attach it to your grease gun, then pump grease through until clean grease is coming out the bearing.
They look like this:
Grip 22200 Universal Bearing Grease Packer - ToolKing.com
Jason
Old Nov 13, 2008 | 04:15 PM
stangbanger's Avatar
stangbanger
WOW ! a no mess way to pack a bearing! Other than that it should be pretty straight foward removing and putting back together. Just work the grease in make sure it packed really good with grease! Its messy
Old Nov 13, 2008 | 04:32 PM
skaterbro's Avatar
skaterbro
I packed my last set of bearings using a food preserver and air tight bags. Saw it on Powerblock and had to try it.
Old Nov 13, 2008 | 04:36 PM
andym's Avatar
andym
No such thing as a no-mess way to pack bearings, unless you count dropping the truck off at a shop. I have a bearing packer like the one Jason posted. I bought it at Kragen for a few bucks. Well worth it, as the manual method is much harder and nowhere near as effective. That being said, a rotating squeal is far more likely to be u-joints than wheel bearings.
joegeds
Oct 9, 2014 11:25 AM
stainlessstroker95
Jun 1, 2011 08:00 PM
bigunred
Modular V10 (6.8l)
Mar 9, 2009 11:15 AM
siphor84
Jan 11, 2005 10:38 AM
JJDDOOGG
Nov 27, 2002 12:18 PM
