Should I replace needle bearing with regular bearing change?
I have a 96 F150 4X4 with a Dana 44 front axle. I'm going to replace the bearings (inner/outer bearings with racers, as well as the oil seal). While I'm in there, should I replace the needle bearing and seal as well? How hard is it and do those fail very often? Is it worth it?
To remove that bearing, get yourself a slide hammer (you can rent one at an auto parts store) and a pilot bearing puller like this:
OTC Pilot Bearing Puller, 6 In L - G4458492 at Zoro
I got one from Autozone for about $15.
Then remove the bearing like this guy did in this video (fast forward to the 9:00 mark):
Cyrusjohn
13
06-24-2017 08:30 AM
Mizuez
24
05-06-2016 08:31 PM
