351M main bearings
Old Nov 25, 2002 | 05:29 PM
JJDDOOGG's Avatar
JJDDOOGG
351M main bearings
Can i change the main bearings and rod bearings with motor in the truck? Or does it have to be pulled?
Old Nov 25, 2002 | 09:32 PM
shazam's Avatar
shazam
351M main bearings
You can do it in the truck .. just drop the pan and loosen the caps ..
But it does work a easier if you pull the motor and put it on an engine stand .
Old Nov 26, 2002 | 01:33 AM
Brian S's Avatar
Brian S
351M main bearings
Under the truck is a miserable job for swapping bearings. Please wear good eye protection. Maybe loosening the torque converter nuts will give the crank a little more free play. Anyone?
Old Nov 26, 2002 | 09:20 AM
Bill_Beyer's Avatar
Bill_Beyer
351M main bearings
What Brian said is correct. It's a dirty, messy, uncomfortable job. Wear safety goggles and clothes you don't care about because you're gonna be covered in drops of oil...soaks right through the coveralls while you're laying there.
I only did the mains when I did it so I can't speak for the rods but the biggest PITA was the 2 piece rear main seal. Had to use a brass drift to punch it out and then sliding the new one in even with the main caps off was no fun. Didn't think about loosening the TC bolts. End result however was no leaks and much better oil pressure.
Old Nov 26, 2002 | 05:35 PM
79_250RangerLariat's Avatar
79_250RangerLariat
351M main bearings
Rods are easier to changed than the mains since you can push the piston up, just be careful when pulling it back down that you don't scrape the crank journal. I found if possible let the engine set a few days before hand and drain all the oil out. Still get drops though. Depending on your rear main you might be able to take a dry wall screw and screw it into the seal, then pull it down out.
79 250 Ranger Lariat 4wd 400 C6 3.55's 33x12.50 16.5's
78 Bronco Custom 4wd 400 C-6 3.50's 31 10.5 15's
66 Mustang Coupe Sports sprint 200 c-4 cruise o matic 3.00's
99 Grand Prix GT 230 ft/lbs torque out of a non turbo'd 6 cyl hehe
Old Nov 27, 2002 | 12:18 PM
Bill_Beyer's Avatar
Bill_Beyer
351M main bearings
sickpup2
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 25, 2020 04:35 AM
RP27G8G
Escape & Escape Hybrid
Feb 3, 2014 01:46 PM
MONAVIERONJON
Sep 18, 2013 05:24 PM
father/son
Oct 18, 2007 10:27 AM
1978fordf250
Sep 3, 2006 06:42 PM
