Backfiring when back driven
Old Nov 12, 2008 | 08:18 AM
yukgoon's Avatar
yukgoon
I recently replaced the intake and exhaust manifold, carb and the mix on my 300 with a Clifford 6=8 and the Holley 390 carb. The timing is set to 6 off TDC and the truck runs great. However, when ever I get off the gas after a quick acceleration or am coasting down hill the engine backfires like a mad man and seems to be back driven by the transmission. This only happens with its in gear. Could this be a vacuum advance problem off the distributer or is there something else that could be causing this problem?
The truck is an 82 F100. The transmission is a 3 w OD on the floor. The transmission was just rebuilt and the engine has 230,000 on it and is still as strong as ever.
Old Nov 12, 2008 | 10:24 PM
Ford_Six's Avatar
Ford_Six
You have a rich idle mixture, and a leaky exhaust. The strong negative pulse of the exhaust while under engine braking draws air in, which allows the extra fuel to burn, making a bang.
Old Nov 13, 2008 | 04:53 AM
srercrcr's Avatar
srercrcr
Could the Valve timing be off? Still unburned mixture in the chamber when the exhaust valve starts opening?
ColtonMullis
Jan 20, 2014 03:53 PM
Austin J.
Aug 26, 2012 06:02 PM
08gasurveyor
41
Jan 20, 2012 09:05 AM
1yamman350
Apr 18, 2006 03:08 PM
longhorn
Jun 19, 2001 05:08 PM
