Do they all backfire?
Old Aug 25, 2012 | 10:36 PM
Austin J.'s Avatar
Austin J.
I have been told that all these old trucks do this, but I wanted to check it out. I have a 75 F350 dually 4 speed with the 390. It backfires when I let off the gas for deceleration. The other older carbed truck I have backfired, but it's engine is dead now. Is this backfiring normal and can it harm anything? Thank You.
Old Aug 25, 2012 | 10:39 PM
Thunderjet4x4's Avatar
Thunderjet4x4
Not normal. Improper tune, and or worn engine parts.
Old Aug 25, 2012 | 10:43 PM
Austin J.'s Avatar
Austin J.
It really isn't every deceleration, only when going fast, down hill, or after downshifting when the engine is holding it back.
Old Aug 25, 2012 | 11:02 PM
jacks61ford's Avatar
jacks61ford
sounds like a small exhaust leak
Old Aug 25, 2012 | 11:08 PM
kobaltblue's Avatar
kobaltblue
^^^^^What he said^^^^^
Are you sure its a back fire? If it is somethings wrong...Most back fires are when you accelerate from a short lean condition.
Old Aug 25, 2012 | 11:11 PM
montana_highboy's Avatar
montana_highboy
A truck with a manual transmission reacts differently than a truck with an automatic transmission under coasting and deceleration scenarios.
When you coast or decelerate the engine acts as a brake, that's when you'll get the cackle and popping sound i.e. "backfiring".
It's just unburnt fuel igniting within the exhaust system, it's pretty normal and nothing to be concerned about, unless of course you're referring to some huge backfire out the exhaust.
Old Aug 25, 2012 | 11:41 PM
Austin J.'s Avatar
Austin J.
It is just small popping and and crackles usually unless a load is on it down hill. The other truck had major backfiring. i thought it wasn't a real concern, but i wanted to be certain. it may be a combination of the exhaust leak and usual popping because the exhaust isn't in the greatest of shape, and thanks for all the response so quickly.
Old Aug 26, 2012 | 06:02 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Yes, Small quiet, almost inaudible with the windows up, popping with a manual tranny is normal, in lower gears going down hills when you "engine brake".
"Ka-blam" type explosions that sound like gunfire, tend to blow holes in your muffler, and scare the heck out of your neighbors is not.
thaxton171
Jun 10, 2018 01:25 PM
ethanmyers7
Jul 27, 2013 09:20 AM
knucklehead11
Bronco II
Aug 8, 2003 02:46 AM
