7.3 wont start when warm
Old Nov 11, 2008 | 02:31 PM
Fordfreak1978's Avatar
Fordfreak1978
Exclamation 7.3 wont start when warm
Hey guys just turned 100,339 mile in my 7.3l. Basically engine starts when cold, but when it gets warmed up and i turn the engine off, when i go to start it again, it often will not start. this doesnt happen every time. I turn the key the glo plugs come on fuel and oil pumps come on, but when i go to start it no power gets to starter. maybe alternator?? I just had it into ford for the cam sensor recall, and was maybe wondering if that had something to do with it. any suggestions are appreciated.
Old Nov 11, 2008 | 03:23 PM
megawatt00's Avatar
megawatt00
When you turn the key do you hear the starter solenoid click?
Old Nov 11, 2008 | 04:37 PM
stangman516's Avatar
stangman516
could be the starter solenoid is getting too hot... if you don't hear the starter solenoid clicking over when it won't start, this is most likely your problem.
Action4478's Avatar
Action4478
My wag is it needs a starter ,,,
Old Nov 11, 2008 | 06:43 PM
Fordfreak1978
ya i hear the starter selenoid click on.
Old Nov 11, 2008 | 06:45 PM
megawatt00's Avatar
megawatt00
Have someone try to start the truck and test for voltage at the solenoid or the starter. I'm willing to bet that the starter is on it's way out.
Old Nov 11, 2008 | 06:49 PM
rob460's Avatar
rob460
starter
does it spin fast or slow like the batteries are low ,if slow take starter off and jump it with jumper cables and see if it still spins slow ,if so then get a new starter ,very common problem .
Old Nov 11, 2008 | 07:29 PM
just another truck's Avatar
just another truck
I agree with everyone, sounds like a starter, if you want to verify, knock a couple of decent times with a hammer, it most likely will start..
Old Nov 11, 2008 | 07:30 PM
just another truck
the starter by the way, knock the starter...
Old Nov 12, 2008 | 06:26 AM
tommyl's Avatar
tommyl
Make sure that the cables on both batteries are tight! And that both batteries are good..
Old Nov 12, 2008 | 06:44 AM
bdrummonds's Avatar
bdrummonds
Original batts? If so they are dead. replace batts. BOTH at the same time.
Old Nov 12, 2008 | 08:02 AM
RubberDuck's Avatar
RubberDuck
Just to think out of the box, if it's an auto, sometimes the gear selector has slack and won't let the starter click over. But if you hear the starter solinoid click, most likely a bad connection, or starter.
Old Nov 12, 2008 | 09:04 AM
bdrummonds's Avatar
bdrummonds
to expand on why I suspect the batts, when your truck sits for a good while the batts naturally have a tendency to regain some of their lost charge, this explains why its eaisier to start when cold, it has more than 10.5V going to the IDM which is the minimum required. Your Alternator is also probably failing. Once you get it started the truck runs off the voltage that is supplied back to the batts from the alt., but its not enough to charge the batts and run the IDM (the IDM takes between 10.5 and 12V and converts it to 120V+ to fire the injectors.) remove batts and have them load tested seperatley. If they check good, then have the alt checked. Only replace batts in sets of two, and if the alt shows bad and this has been happening awhile, replace batts and alt. a failing alt can damage good batt cells in a short time.
Old Nov 12, 2008 | 09:15 AM
rbaker6336's Avatar
rbaker6336
is it the relay on the inner fender clicking or the starter solinoid?
when you get a no start try jumping across the big post on the relay
if it starts then try jumping from bottom large post to small post
TAZ01
Jun 25, 2013 11:54 PM
1'stonraceday
Dec 26, 2012 10:12 PM
jeffvitt
Feb 16, 2012 08:36 AM
jeem
Feb 6, 2011 11:10 PM
kdokey
Dec 29, 2009 12:36 PM
