Truck quit during idle and now wont start
I had my 99 7.3 idling while I was jumping the wife's mini van. First it dropped out of high idle by itself (never did that before), then while it was idling it just quit. I tried to restart it (engine is warm) and it would not start. I notice that the "Wait to start" light in the instrument was not coming on when I would turn the key off then on. I recently changed the glow plug relay and she she was starting just fine. Any ideas?
Thanks, Jim Dawson
Thanks, Jim Dawson
Sounds like they got ya covered just to clarify though you want to:
A. Check if number 31 fuse is blown.
B. If so, disconnect the electrical plug on the back of your fuel bowl
C. Replace the fuse with a new one
D. Turn key on (look for WTS light) and try to start the truck.
What happens is the fuel heating element in your fuel bowl shorts out and blows that fuse. Like what was said above it also controls things like your PCM. Depending on where you live having a fuel bowl heater is not critical but you will want to replace it sooner then later. Heres a helpful link on one of those for a good price and it comes with great instructions.
Replacement O-rings for Ford Diesel Engines
No. Unplug the electrical connection on the back of the fuel bowl filter, replace the fuse and then start your truck up. It won't hurt anything to run the truck with that plug disconnected.
websthes
09-14-2006 06:00 PM
jcd302
21
09-10-1999 09:09 AM
