Push button shifter?
Old Nov 10, 2008 | 01:23 PM
onefarmer's Avatar
onefarmer
The shifting in my '96 sucks. The second to third shift many times waits an impossible long time. I'm sure it's the computerized shift not just a delay of the actual shift.
Has anyone invented a shift control box so a guy could choose his own shift points. I know go get a stick but I have a bad left knee and need the auto, or at least something clutchless
Old Nov 10, 2008 | 01:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are a couple companies that make stand alone controllers for the E4OD. Baumann Engineering and PCS are two that I've heard of. I've never used either so I can't recommend them. I'm just telling you what I've seen around the 'net.
Old Nov 10, 2008 | 06:37 PM
c00nhunterjoe's Avatar
c00nhunterjoe
try installing a shift kit, takes care of alot of complaints
Old Nov 10, 2008 | 06:45 PM
tjbeggs's Avatar
tjbeggs
MADVAN built paddle shifter for his but its one off. A shift kit might help but its not going to change the actual shift points. My recommendation would be to get a chip that is burn with stock power if that where you want to keep it and have TW give you his shift programming. Maybe even a reflash of your PCM to TDE1 programming if its not already done. I would guess you have a NAW4-6 programming and its transmission stuff stinks!
Old Nov 11, 2008 | 07:00 AM
onefarmer's Avatar
onefarmer
I have seen Coons valve body mod and like it for taking the mush out of the shift. It's the shift points that suck. Tw is probably the way I will go. How do I reflash it for the TDE1 program?
It's ok only if I baby it and take a mile to get up to 60mph but anything faster and I'm bouncing in the seat wanting it to shift. Many times I run the throttle like a stick shift. Power on up to speed, back off, shift, power on again ect..
Old Nov 11, 2008 | 10:17 AM
tjbeggs's Avatar
tjbeggs
For a reflash the dealer can do it or you can send your PCM to Dp tuner and they can do it.
hail destroyer
Apr 29, 2016 05:42 AM
AteThePrincess
1983 - 2012 Ranger & B-Series
Feb 21, 2016 04:45 PM
stevenjf88
Oct 28, 2015 10:39 PM
Alby
Sep 2, 2005 07:46 AM
Morley
May 2, 2005 08:13 AM
