steering stabilizer
Old Nov 8, 2008 | 11:01 PM
Trucker51's Avatar
Trucker51
steering stabilizer
Looking to get a new steering stabilizer for my truck. Running all stock suspention. Is a dual set-up worth the extra money for stock tires and suspention?
thanks!
Old Nov 8, 2008 | 11:22 PM
ReAX's Avatar
ReAX
Not really. The reason to go to duals should be to spread the heat generated from the steering oscillation being dampened. A good replacement single will be all that you need. I had found a zinc bilstein that I have been really happy with, I am running a single with 35" Toyo's.
Old Nov 9, 2008 | 03:11 AM
Stewart_H's Avatar
Stewart_H
Ax, does Bilstein have a steering stabilizer available now?
Back when I added mine, Pro Comp was the most cost effective choice, hands down, but I like Bilstein shocks so I'd be amenable to spring for the coin on a Bilstein stabilizer.
Stewart
Old Nov 9, 2008 | 08:55 AM
shadows4's Avatar
shadows4
Smile
I replaced mine with a single Rancho this spring. I August found out the seals were blown out of the stabilizer. With Rancho's lifetime warranty, just took it along with my receipt to local dealer and got a replacement, no charge! Other than that have been very satisfied with the Rancho shocks and stabilizer.
Old Nov 9, 2008 | 12:54 PM
ReAX's Avatar
ReAX
I used a shock off a Volkswagen, it has no pressure and near 50/50 valving. It spec'd out near perfectly for my truck.
Old Nov 9, 2008 | 11:06 PM
wallz's Avatar
wallz
thanks!
I thought about it when I changed mine out this summer. I prefer the look of the dual setup, but couldn't justify the expense, and went with single rancho. With the stock set up single is more than adequate, and I'm happy with mine. Good luck either way you go.
Old Nov 10, 2008 | 08:36 AM
BAJI26's Avatar
BAJI26
I have a 2wd with no existing Stabilizer... what can I do to install on, I like the ranchos.
Old Nov 10, 2008 | 08:45 AM
SD26's Avatar
SD26
What Volkswagen? Squareback? Thing? Rabbit?
Old Nov 10, 2008 | 09:07 AM
ReAX's Avatar
ReAX
Here's the thread with my research https://www.ford-trucks.com/forums/5...abilizers.html
I looked up that PN and It's showing a truck. I must have looked at VW for another project right around that time.
Old Nov 10, 2008 | 11:11 AM
FordTruckGirl77's Avatar
FordTruckGirl77
I noticed my stablizer is crunched in from the previous owner. Could this be causing any problems? I plan on changing out my shocks (bilstien) next week should I just do the stablizer at the same time? Any brands better than others? Thanks
Old Nov 10, 2008 | 12:40 PM
whjco's Avatar
whjco
Mine too was damaged by the previous owner and was leaking. I bought a new Monroe at Advance Auto Parts for about 30 bucks. It took less than 10 minutes to change it and it's been working great.
Old Nov 10, 2008 | 01:03 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Look here: https://www.ford-trucks.com/forums/5...er-on-2wd.html
I need one myself, especially with 35s on.
Old Nov 10, 2008 | 01:40 PM
FordTruckGirl77
30 bucks is cheap! Thanks for the heads up!
Old Nov 10, 2008 | 02:43 PM
1's Avatar
I've noticed my steering feels very loose when going over expension joints in a sweeping highway ramp near my work. Steering wheel used to stay dead stable across these joints, now it shakes back and forth a lot. Seems I'm in the market for a new one as well.
If one was willing to spend some more $, what would be a higher quality option?
Old Nov 10, 2008 | 04:24 PM
FordTruckGirl77
Mine does the same thing, I feel so unsafe at times driving down the freeway. I think I am gonna get one today. I just got back from driving a few freeways and whoa it was all over on the bumps. Ive tightened the steering box and I know its not that. I am also going to order the helwig this week.
